home made body lift
  • bazwidajimny
11 Sep 2008 21:22 #170 by bazwidajimny
home made body lift was created by bazwidajimny
right guys this might not work for you, but has for me. got some box section just under 2" x 3", drilled straight through it, undone all my body bolts removed the lower bush, nkeep the washer, the bolts are just long enough to go through the box and chassis and washer. theres enough thread to get the nut on and do up. the front mounting u have to drill out the thread and use a longer bolt and nut. didnt have to modd anything else,,,,,,,,,2" body lift for £5!!!!! sorry cant get any pics on here the laptop playing up, lol. (try soon)
bazz
  • Gaz
12 Sep 2008 12:05 #171 by Gaz
Replied by Gaz on topic Re:home made body lift
aye , get some pics up old boy
VERY interested in this one .
wanted to try this but dont have the B**LS to
Cheers
Gaz
12 Sep 2008 12:23 #172 by mlines
Replied by mlines on topic Re:home made body lift
From what I gather its pretty straight forward. Ash Awbery (PICTURES) did his in a similar way but I understand he bought some of the bolts etc. from Bits4Vits to avoid running out of thread and other similar problems.
  • bazwidajimny
12 Sep 2008 16:17 #173 by bazwidajimny
Replied by bazwidajimny on topic Re:home made body lift
sorry for no picks try and sort it this weekend but it works fine thear is anuff thread left 2 get the nut on the more u tighten it palls to gether iv since had to cut a bit away behind the 4x4 lever didnt go all the way in and jumped out ov low box BUT evrey thing else ok just make sure the box u use is no biger than the lower rubber body mount and it will work given me a bit more room for my 31s and is a cheap way to do a body lift B)
Time to create page: 0.391 seconds
