Rear seat base removial on 2007 model
22 May 2011 09:58 #16717
by Toad
Rear seat base removial on 2007 model was created by Toad
How do you remove the rear seat base on the later models? I am very reluctant just to use brute force as it will need to go back in some time!
Still think that the earlier arrangement is so much better, but know that it was a safety requirement to change it.
Cheers Toad
Cheers Toad
22 May 2011 15:10 #16739
by Halford
Replied by Halford on topic Re: Rear seat base removial on 2007 model
Hi Toad
you do literally just heave the rear seat up from the front so it "sort" of hinges then rive it off - sounds violent I know.
you can download a step by step photo-guide I've put into a pdf file attached
or here www.4shared.com/document/GK6AWWed/rear_seats_removal.html
I can't take credit for the original work, found it a while ago somewhere else, hope it helps.
Attachment rearseatsremoval.pdf not found
22 May 2011 18:03 #16760
by Toad
Replied by Toad on topic Re: Rear seat base removial on 2007 model
Hi Halford
Thats great thanks so much couldn't have asked for a clearer discription or photos.
Much appreciated,
Toad
Much appreciated,
Toad
- darthloachie
22 May 2011 18:09 #16762
by darthloachie
Replied by darthloachie on topic Re: Rear seat base removial on 2007 model
Bet Martin'll put that on the guides area
- supergaz
22 May 2011 20:11 #16791
by supergaz
Replied by supergaz on topic Re: Rear seat base removial on 2007 model
I cannot see any advantage of the new seat arrangement. Just looks like its a cheaper method to manufacture.
Time to create page: 3.069 seconds
