Over Heating ...
- funkyjimny
- Moderator
- 2004 jimny soft top, factory hardtop, ARB bumper
- Thank you received: 56
22 Dec 2009 12:22 #1672
by funkyjimny
Replied by funkyjimny on topic Re:Over Heating ...
I'd be tempted to say head gasket.
Gary
Gary
- ooky_123
22 Dec 2009 19:35 #1676
by ooky_123
Replied by ooky_123 on topic Re:Over Heating ...
Thought about that, but no water in the oil... even the cold weather and letting it come up to temp, and cooling again has not given any visable signs of water contamination.
Just pordered a new Thermostat from Suzuki ... Will change that and if start there. Failing that, will get a new radiator
- funkyjimny
- Moderator
22 Dec 2009 19:38 - 22 Dec 2009 19:39 #1677
by funkyjimny
Failed head gasket doesnt always mean water in oil, head gasket can go between water jacket and cylinder which pressurises system.
Hope it is something simple like a thermostat though, check yours by removing and placing in a cup of boiling water and see if it opens etc
Gary
Gary
Last edit: 22 Dec 2009 19:39 by funkyjimny.
- ooky_123
06 Feb 2010 18:24 #2208
by ooky_123
Well, finally managed to put some miles on the Jimny.. after a failed attempt to remove the tow bar ( gonna have to get the angle grinder out ).. I decided to take a wander across the Plain ( Big Military exercise (pre Deployment) in progress). There is Lots of Mud and slurry due to lots of heavy armour movements, so the mud is thick and the slopes slippery.
After about 300 meters of hard climbing, I noticed the temp was right on the Upper limit again.
Now having washed quite a lot of silt out of the radiator, and replaced the thermostat, I figured this problem was resolved, but I fear not. (right, down with the windows, and heating on full !! ).
I thought it mabe be because I have relocated the front number plate across the bonnet vents using cable ties, but there is ample air flow though the bumper appeture.
Washing down the Jimny outside, I managed to get another load of silt from the Radiator, and when the vehicle had cooled down, The water level in the Radiator had not changed.
I think The answer is a new radiator. The existing one has loads of damaged fins, and as im still getting loads of silt from it, I think a new Rad is the better option.
Is anyone able to recommend a suitable upgrade for the standard Radiator .. or is it a case of picking up a replacment ?#
Also Thinking of putting an electric fan on instead of the viscous coupling standard one. (again, any recommendations ?)
