SJ t-box in jimny
  • Baz2236
14 Dec 2009 18:46 #1598 by Baz2236
SJ t-box in jimny was created by Baz2236
Hi people I thinking of buy off road armoury t-box conversion kit. Would a standard sammy t-box be much of a reduction to the Standard jimny gearing.
  • suzukisan
23 Dec 2009 19:48 #1683 by suzukisan
Replied by suzukisan on topic Re:SJ t-box in jimny
Hi Baz
I'm in the middle of moving my ORA t-box from my sammy to my jimny. I did some research and there is definately a useful reduction in gearing although I can't remember how much. I'm mainly doing it so I can still drive it with my monster Insa Special Track 31" tyres that should fit after all the other work has been done as well.
Once finished I'll post a report on what it is like.
Steve
  • suzukisan
23 Dec 2009 19:49 #1684 by suzukisan
Hi Baz
Steve
  • JIMNY EXTREME 4X4
23 Dec 2009 20:27 #1685 by JIMNY EXTREME 4X4
Replied by JIMNY EXTREME 4X4 on topic Re:SJ t-box in jimny
hmmmmmm depends really on how you drive and what size tires you are running. if your running 30's and love to give it lots of right boot then it should be fine, but if you are more into rockcrawling up creek beds and slow driving or even if your running tires 31's and up, a set of crawler gears would be a good investment otherwise you can say bye bye to your clutches haha just my two bobs as i have experienced this myself i burnt out 2 clutches before i put reduction gears in.
23 Dec 2009 21:18 #1686 by funkyjimny
Replied by funkyjimny on topic Re:SJ t-box in jimny
Nope, std 410 case should give you 15% ish reduction in high and low, sammy i dont think dives you anything. Get a sammy box and a 410 box, send them both to rockwatt on muddyzook forum and get him to make you a crawler rocklobster box, 15% reduction in high, 80% ish in low. This creates a 4.16:1 ratio box, i have a Rob Storr 6:1 box and flat out in 5th low is less than 20 mph lol.
Gary
  • ryansjimny
05 Jan 2010 19:43 #1811 by ryansjimny
Replied by ryansjimny on topic Re:SJ t-box in jimny
I've got access to a 410 transfer box, and am thinking about fitting it into the jimny.
Has anyone on here got any previous expirience of this conversion? flange compatability, will the sammy box speedo convertors fit etc?
Time to create page: 0.227 seconds
