How to increase steering wheel reaction?
- THOR
03 May 2011 19:04 #15827
by THOR
How to increase steering wheel reaction? was created by THOR
Hi guys...anybody knows how to increase the steering wheel reaction?
My steering feels very light and there is a delay when i turn the steering wheel before the wheel turns where i want it to go.
I experienced this after a suspension lift. I already installed a steering stabilizer for vibrations and shimmy.
Additionally, I hear a clacking sound when I turn the steering wheel initially, then the sound would be gone...
- Thank you received: 115
03 May 2011 19:26 #15828
by maverick
Jalapeño, IISY?
Replied by maverick on topic Re: How to increase steering wheel reaction?
sounds like you need Caster Corrected Radius Arms or Bushes!
Jalapeño, IISY?
- THOR
03 May 2011 19:55 #15831
by THOR
Replied by THOR on topic Re: How to increase steering wheel reaction?
hi maverick thanks for the reply...
recently i had my jimny checked for wheel alignment, and they said that my caster and camber alignments are ok (toe needs a little adjustment).
do i still need a caster correction arms and bushes?
- THOR
03 May 2011 20:04 #15833
by THOR
oh by the way, i did not install an adjustable panhard rod...i'm still using the stock.
So my axle is a bit off-centered and out to the left a bit...
can this cause the problem with my steering (including the clacking sound)?
04 May 2011 03:49 #15836
by facade
Replied by facade on topic Re: How to increase steering wheel reaction?
A cracking sound is most likely dry kingpin bearings.
A knock is play in a steering joint.
To get more self centring reaction you need more caster angle.
Having the axle out of line will make the car crab and steer a bit odd, as well as moving the wheel off centre.
- THOR
04 May 2011 04:08 #15837
by THOR
hi facade...
so i need to lubricate the kingpin bearings?
how do i correct a play in the steering joint?
I guess i really have to install an adjustable panhard rod, because the steering sometimes is a bit odd..as you mentioned sometimes "crab-like"..
i think i will install the caster correction bushes later, as i don't need self-centering reaction from my steering too much...
sorry, i'm such a newbie at this...
Time to create page: 0.288 seconds
