need help in changing bulb in the the dash board
  • NOAM
23 Apr 2011 15:39 #15392 by NOAM
hi,
my first time hear (and english is not my mother tongue- so be kind with any mis-spells.
i need to chang a bulb or two (actually, i'll replace them all) in the dash-bord.
the place is behind the speedometer. ooops!
is there an easy way to do it? or do i have to dismantle the whole dash-board unit?
i'm worry that afterward it will start making noises...after all it is made our of plastic.
thx
noam
  • DVs-Jimny
23 Apr 2011 16:11 #15393 by DVs-Jimny
You need to remove the upper dash (two screws above the instruments), then gently pull the plastic upper dash up and off. (Much easier to do than it sounds). You now have access to remove the clocks etc.
Hope that helps.
  • NOAM
24 Apr 2011 10:24 - 25 Apr 2011 18:16 #15412 by NOAM
thx!
it sound easy to do/
the two screws are those infront of the clock and on the upper?
are there any plastic acrews that may break (like all the other screws that suzuki put).?
Last edit: 25 Apr 2011 18:16 by mlines. Reason: EDITED FOR LANGUAGE - PLEASE DO NOT SWEAR ON BIGJIMNY
  • andyw
24 Apr 2011 10:55 #15413 by andyw
:ohmy: ...............nothing wrong with your spelling (F******d) , crap screws is much better when kids read things on site....;)
cheers
Andy
  • DVs-Jimny
24 Apr 2011 11:31 #15414 by DVs-Jimny
The two screws are on the inside top of the dash (speedo, rev counter etc), once removed you can lift and pull away the plastic upper that covers the clocks, heater vents etc. You might get caught up on the hazard switch if it is on top of the steering cowling but there are no other screws to remove. (Mines a 1999 model)
Time to create page: 0.137 seconds
