RockLobster Front Prop
22 Apr 2011 20:43 #15360 by MigCooper
Hi
Today fitted my rocklobster I got from rockwatt as many of you around.
I got the box, and 2 shafts from him witch seems ok according to the manual from here.
The only thing is the front prop, same as original (Jimny one) seems to be quite a tight fit, there is only a 2mm gap or so .... is this the way it should be? it seems that if I go over a bump it will put some back pressure in the transfer case or maybe not? can anyone shed some light on this?
Thanks ;)
Jimny is lifted 3" anyway ... :)
Snorkel and plenty of rust to be treated :)
  • jimny5
23 Apr 2011 04:38 - 23 Apr 2011 04:40 #15363 by jimny5
Replied by jimny5 on topic Re: RockLobster Front Prop
I had the same issue,its all about suspension, been told that you have to run a min of 3in lift, and some 3in kits are Not 3in, more like 2.5in. Or if its old And sagging.
So you can fit spring spacers, dosent make a great difference.
Or chop a bit of the prop or i've heard that a 4.10 prop is shorter-dont know if this is true.
I just chopped abit off mine as i had a spare if it was too much.
Mike.
Last edit: 23 Apr 2011 04:40 by jimny5.
23 Apr 2011 07:01 #15366 by MigCooper
Mike
I have 3" lift and almost new ... it's from KAP and from what I remember measuring it was more then 3 when fitted and 3 after a few weeks of settling ... B)
The front prop will fit, but it will be almost fully compressed... :S Due to the angular movement from the radios arms is it doing to move that far back that I need to shorten the prop? if so by how much?
thanks guys
23 Apr 2011 10:41 #15376 by facade
Replied by facade on topic Re: RockLobster Front Prop
Personally, I'd shorten it to get the sliding end in the centre of the splines when the car is standing level.
23 Apr 2011 13:39 #15384 by MigCooper
I was talking to Rockwatt today and he said that's ok to be like that and there will still be some movement which is enough.
Anyone else with a SJ413 box in the jimny can say what they have done...
Thanks ;)
  • vitara_mad
23 Apr 2011 14:47 #15387 by vitara_mad
Replied by vitara_mad on topic Re: RockLobster Front Prop
my lobster box fitted fine with the standard jimny front prop , sammy front on the rear & sammy little prop
