AXLE BREATHER KIT
  • gazert
12 Apr 2011 03:09 #14857 by gazert
Replied by gazert on topic Re: AXLE BREATHER KIT
You have to pull all those caps off and you kit pushes inside the hole.
I used a spark plug cap and pushed it over the outside.
Job is easy.
12 Apr 2011 04:59 - 12 Apr 2011 05:28 #14858 by dirtydogz
Replied by dirtydogz on topic Re: AXLE BREATHER KIT
This is a link to BIGGAZ with lots of photos of his jimny mods.
www.bigjimny.com/index.php?option=com_ku...=8&id=5998&Itemid=75
Hope this helps DIRTYDOGZ
Well got this little lot today
Attachment IMAG01631.jpg not found
all sorted
Attachment IMAG01651.jpg not found
See on the fitted pic, where the hose pipe which was supplied is slotted over breather exit then ive put the pipe clip thing straight into that? You got two other reducers which im guessing went from the hose pipe into the reducer clip but the diameter of the hose and the black reducers was too different so the hose wouldnt have tightened round it snugly??
Did anyone else use the black reducers aswell between the hose and the reducer clip?
Cant see any probs the way ive did it though, fit nice and tightly into hose and cable tied on.
gaz.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 12 Apr 2011 05:28 by dirtydogz.
12 Apr 2011 08:12 #14862 by ooky_123
Replied by ooky_123 on topic Re: AXLE BREATHER KIT
Former owner of Little "Ooky", who has now started a new life in Shetland
  • Nelson83
12 Apr 2011 08:37 #14863 by Nelson83
Replied by Nelson83 on topic Re: AXLE BREATHER KIT
I've been poking around under mine these last few weeks and noticed that on top of the axles there are what appear to be "thimble" shaped covers that should pop off - guessing these need removing and the kit pushing in to the holes. :unsure:
So for the tight fist approach (having read this and the previous thread and what kirkynut says), all i need is a couple of jubilee clips, length of garden hose pipe and some cable ties, then push the hose over the breather and route them up the chassis to the front of the bulkhead?
12 Apr 2011 08:52 #14866 by ooky_123
Nelson83 wrote: I've been poking around under mine these last few weeks and noticed that on top of the axles there are what appear to be "thimble" shaped covers that should pop off - guessing these need removing and the kit pushing in to the holes. :unsure:
Yes. The caps do take quite a bit of prising to get off, but as long as you can seal the hose onto it with a jubilee clip, you should be ok.
I fed mine right up into the snorkel head (and back into the airbox) as I had extra pipe and didnt want to cut it !!
  • Nelson83
12 Apr 2011 09:31 #14874 by Nelson83
Well, i've got the jubilee clips and cable ties - just need to raid the shed and hack a length of the hose pipe without me old man realising where its vanished too!!! :lol: Doubt he'll look under my truck when he can't water all the plants :whistle:
