Tube in a tubeless tyre?
07 Apr 2011 11:11 #14663 by Johnniehec
I'm getting a tube fitted "at my own risk" because of the "ribs inside the tubeless tyre" reason above, by an independant, as I said,
"The cut is about 10mm long on the outer layer only and the actual hole must just be a pin hole as it only bubbles really slowly with soapy water, it was a b****r to find. There is no bulging or distortion around it."
So ther's no cords showing in fact there are bigger deeper cuts/scratches elsewhere and on other tyres that are not leaking.
Personally if I'd had access to a tyre changer machine I'd have tried a puncture repair patch on the inside as the hole is so small.
  • Little Terror
07 Apr 2011 18:44 #14680 by Little Terror
Replied by Little Terror on topic Re: Tube in a tubeless tyre?
Sometimes with inner tubes the tyre can spin on the rim a little and rip the valve out as specially with low air pressure.
08 Apr 2011 06:07 #14685 by maverick
I have tubes in my tubeless Diamond Backs .. I go to ATS (as KwikFit dont do tubes) .. cost about £20 fitted.
Jalapeño, IISY?
Time to create page: 0.323 seconds
