CV Joints
05 Apr 2011 12:34 #14513
by Obarno
I seem to remember reading that early and late cv joints are not interchangeable as they have different spline numbers. Is this correct? Would early front shafts and cv joints as an assembly - 2000 - fit a late -2007 - car? I know the diff end is the same number of splines - 22 - and I presume the outer flange end is the same as there appear to be only one type of freewheeling hub offered across the range.
The reason I want to know is that I have a pair of shafts and cv joints from an early car which I would like to use as spares on a late car if/when I brake a cv joint.
As an aside has any one used D&Gs Birfield rings on their cvs and do they really make a big difference?
05 Apr 2011 16:53 - 05 Apr 2011 16:59 #14529
by kirkynut
Replied by kirkynut on topic Re: CV Joints
I have a set of late shafts and CV's and a set of early shafts and CV's and both have the same number of splines and as a unit they are interchangable.
What you can't do I think is change the CV's onto their opposite shaft.
I know some diff ratios changed but I don't think the shafts did, not at the front anyway. This is why all freewheeling hubs fit.
In respect of the Birfield Rings, I believe they will help trememdously but have not tried them. The CV's go by way of the outer casing being pushed out and cracking by the pressure of the balls. If the casing is held together by the Birfield Ring also, it has been strengthened somewhat.
They are not cheap though! I can see from your signiture that you have front and rear ARB's - have you considered contacting KAM Diffs as they were bringing out hardened front shafts and CV's and already sell hardened rear shafts cheaper than D+G.
You have an auto though, so in theory you can feed the power in a little more gently and not break things, but that depends on your right foot and how heavy it is. Have you broken CV's / shafts already?
You don't have the most aggressive tyres with KL71's to go snapping things with alot of grip.
Last edit: 05 Apr 2011 16:59 by kirkynut.
- bluejimny
05 Apr 2011 17:11 #14531
by bluejimny
Replied by bluejimny on topic Re: CV Joints
ive had 3 CV's go on mine, but have all failed differently, one the outer gave up, so like you say the rings would help to beef up the CV, but then something else would be more likely to fail, when at the big jimny event it seems the inner part with the splines gave up on me
ive been speaking to a transmission manufacturer today as he makes uprated CV's halfshfts etc, and from his experience its the cage that hold the balls fails quite often and then causes the CV to go
he was quite surprised to see how thin the cage was on jimny CV's but he's comparing them to Subaru CV's
we looked at the possibility of using a larger CV's and making custom halfshafts to suit but there just isnt the room in the jimny axle to do this
the only other method is making the CV's out of a stronger material but thats when the cost goes up!! :S
05 Apr 2011 17:26 #14534
by kirkynut
This is it, the cost of uprated shafts and CV's. I'll not get a locker I don't think.
Have you had lockers in when you broke your CV's???
- bluejimny
05 Apr 2011 17:50 #14541
by bluejimny
no thats the thing just an open diff, its probally when the spining wheel does get that bit of grip
at big events now i might just take a set of front halfshfts with me as i can change them now within the hour
05 Apr 2011 18:08 #14546
by kirkynut
Oh dear, that was my fear about getting aggressive tyres as I now have with my Malatesta Kaimans as I have a Rocklobster and effectively will not be much, if any different to you now!
My Mrs has a heavy right foot sometimes and has learnt how to drive offroad in an SJ410 with hard springs and then the Jimny with the old transfer box, neither with particularly aggressive tyres!
Now we have grip and low gearing it's all a bit different to what she's used to and mechanical sympathy she aint got!
I have a set of spare front shafts with good CV's on so I will carry them with me if we go far from home. I'm lucky in that our club site is only a few minutes from home, so we could free up the front huns and limp it home, but further afield could be different.
Like you, now I've changed front wheel bearings and Kingpin bearings, axle seals etc, I can change a front shaft in less than an hour, but I don't want to have to!
Time to create page: 0.209 seconds
