rear winch tray piccies for kirkynut
  • darthloachie
02 Apr 2011 17:37 #14373 by darthloachie
rear winch tray piccies for kirkynut was created by darthloachie
Attachment winchtray1.jpg not found
to use the winch you take off the rear number plate
Attachment winchtray2.jpg not found
I think it is based on a tow bar with plates welded on to form a floor and sides and reinforcing square tube at the back to take the weight of the winch
Attachment winchtray3.jpg not found
also a recovery hook and shackles welded on for rear recovery points
Attachment winchtray4.jpg not found
Attachment winchtray5.jpg not found
Attachment winchtray6.jpg not found
Attachment winchtray7.jpg not found
Attachment winchtray8.jpg not found
Attachment winchtray9.jpg not found
  • Brian.SMC
02 Apr 2011 17:59 - 02 Apr 2011 18:01 #14376 by Brian.SMC
Replied by Brian.SMC on topic Re: rear winch tray piccies for kirkynut
Some more inspiration for you mate
Last edit: 02 Apr 2011 18:01 by Brian.SMC.
03 Apr 2011 07:26 #14386 by kirkynut
Cheers chaps. I had seen the foreign one and it looks good. I wondered about using the tow bar or at least its mounting points for the rear of the tray but the front would need mounting. I think it would need mounting in 4 corners due to the forces concerned that could otherwise twist it.
I can't afford another winch and rope now but will show these piccies to my fabrication guru mate and together we shall come up with something using ideas from here and there and when that day finally comes ill post piccies!
Thanks again.
  • Brian.SMC
03 Apr 2011 07:44 - 03 Apr 2011 07:45 #14387 by Brian.SMC
The chassis already has the holes to bolt the the one above in place.
That is how I have mounted the rear bumper I made for mine. Can be pulled off the truck in minutes if needed. Just weldd nuts in place before slotting into chassis legs.
I can't remember what site the one above is on, I am sure it's Finnish or Swiss.
Last edit: 03 Apr 2011 07:45 by Brian.SMC.
Time to create page: 0.346 seconds
