SWIVEL JOINT SEAL
- myers647
14 Mar 2011 21:31 #13382
by myers647
SWIVEL JOINT SEAL was created by myers647
HI THIS MAY BE A REALLY STUPID QUESTION TO YOU GUYS HERE IT GOES,
IV CHANGED BOTH KING PIN BEARING OVER THE LAST 6 MONTHS BUT NOW NEED TO REPLACE THE SEALS. AFTER LOOKING AT THEM I NOTICED THAT THE TWO METAL OUTER RINGS ARE SPLIT WHICH I CAN GET ON BUT HOW DOES THE RUBBER SEAL GET OVER THE SWIVEL JOINT AS IT HAS'NT GOT A SLIT IN IT OR WILL IT STRETCH OVER.???
YOUR HELP WOULD BE APPRECIATED
15 Mar 2011 08:37 #13395
by mcjimny
Replied by mcjimny on topic Re: SWIVEL JOINT SEAL
Unless you have it all apart for the kingpin job, i was advised on here that the workshop manual states to cut them. I did this recently one side was apart so theres enough room but cut the other side. Just put the join away from the other join in the metal rings.
According to the service schedule these should be changed every 12months.
* theres no need to shout either lol! :laugh: :laugh:
15 Mar 2011 16:21 #13412
by kirkynut
Replied by kirkynut on topic Re: SWIVEL JOINT SEAL
I wouldn't cut them as the gap where they have been cut will let water through. I read to cut them but would not for this reason.
- myers647
15 Mar 2011 16:31 #13414
by myers647
Replied by myers647 on topic Re: SWIVEL JOINT SEAL
Thanks for the reply 's but im none the wiser do i dont i.????
thanks n sorry for shouting lol
15 Mar 2011 17:19 #13418
by mcjimny
2 choices:
Leave them until you inevitably have to replace the kingpin bearings again and don't cut them, until i learnt that they needed doing annually they'd been on for 2+ years of my ownership without changing so potentially 3 years or more.
Or cut them, when i cut mine i was a bit dubious about how it would work but when you push the seal in theres no gap i triple checked and the metal rings prevent any movement. Just make sure you use something very sharp and clean so its a good cut. Cutting them is less than ideal imo but i'm not about to pull it all apart for a 5minute job.
- myers647
15 Mar 2011 17:29 #13420
by myers647
yes thats what i thought i didnt want to strip it all down again.
ok il give that a go because its really worn on one side.
thanks
thanks
