DISK BACKING PLATE BOLTS
- myers647
26 Feb 2011 19:20 #12216
by myers647
Hi there does anyone know the size of the 4 bolts that secure the disk backing plate on. I was going to change my kingpin bearing today but couldn't get the last bolt off typical eh. An I didn't want to just cut it off because I use it for traveling to work every day.
Thanks
DISK BACKING PLATE BOLTS was created by myers647
Thanks
- mcjimny
26 Feb 2011 19:28 #12218
by mcjimny
Replied by mcjimny on topic Re: DISK BACKING PLATE BOLTS
iirc 14mm, soak it over night with a lot of wd40.
- wildfire
26 Feb 2011 19:30 #12219
by wildfire
Replied by wildfire on topic Re: DISK BACKING PLATE BOLTS
If thats the thin metal plate, on the inside of the break disk, then i had the same problem. I striped one bolt trying to get the bugger off. In the end i could not even remove one so i found if your very carefull you can remove the vacume pipes by reaching around it and using a flat bladed screw driver. It is a lot tricker than normal.
26 Feb 2011 19:32 #12220
Replied by mlines on topic Re: DISK BACKING PLATE BOLTS
M10 x 25mm x 1.25 (Metric Fine)
- mcjimny
26 Feb 2011 19:38 #12221
by mcjimny
I realise you needed something more useful after posting :blush:
- bryandenham
26 Feb 2011 19:39 #12222
by bryandenham
Replied by bryandenham on topic Re: DISK BACKING PLATE BOLTS
You don't need to remove the disc or backing plate to change king pin bearings. I did explain a few weeks ago. just take the caliper off and hook it out of the way, take off the ring of bolts holding the big seal on and after removing the kingpins pull off the whole hub complete with the half shaft. Simples !! half an hour each side and voila.
bryan D.
bryan D.
Time to create page: 0.170 seconds
