Narrow or wide MT-Tires: 215/75 R 15 or 195 R 15?
  • biggaz
21 Feb 2011 11:44 - 21 Feb 2011 11:46 #11914 by biggaz
Mine are 215/75 and fit without rubbing archs etc before i had any lift. i have bfg km2 and there brilliant on road and seem great in the mud aswell.
Expensive though,
Last edit: 21 Feb 2011 11:46 by biggaz.
  • Monkey
21 Feb 2011 11:48 #11915 by Monkey
Canoodle Moose wrote: ...will I need a bodylift for the 215/75R15 or will a 2" suspension suffice?
As far as I know, the 2" suspension allows for full shock strut compression so, if the terrain calls for it, the car comes as close to the tires as the standard suspension. Hence, If 215/75 R15 might rub without lift, they might also rub with "only" a 2" suspension. So, maybe the 215/75R15 need a little bodylift also?
If really wanted to you could get 235's under with a 2"inch lift but you will need to chop your front bumper up. Here in Aus a heap of guys run 215's with no form of any lift.
No need for a body lift unless you are going to 30x9.5 or 31's!;)
  • Canoodle Moose
21 Feb 2011 18:53 #11942 by Canoodle Moose
Replied by Canoodle Moose on topic Re: Narrow or wide MT-Tires: 215/75 R 15 or 195 R 15?
Thanks, Folks!
  • biggaz
21 Feb 2011 19:20 #11951 by biggaz
Attachment IMAG0109_2011-02-21.jpg not found
mine on standard height with 215/75
  • Canoodle Moose
21 Feb 2011 20:38 #11975 by Canoodle Moose
Nice! Looks a bit tight, but nice!
What make/type of tires?
  • biggaz
22 Feb 2011 05:21 #11984 by biggaz
Bf goodrich mud terrain km2
Looks tight in pic but they were fine!
