Supension: OME or Trailmaster (2 / 50mm)
- Canoodle Moose
20 Feb 2011 18:38 #11872
by Canoodle Moose
Supension: OME or Trailmaster (2 / 50mm) was created by Canoodle Moose
Hi Folks,
I am new here and the proud owner of this 1998 Jimny VX FJ which I just bought as my hunting car (I have two other cars for the street etc):
(no jokes about the color please)
I only want to use the Jimny for the 10Km to my hunting grounds and the partially extreme terrain there. We have an altitude difference of 200m, steep forrest and wet areas. Since I live in Austria, we have all surfaces from forrest ground to mud, snow and ice.
So, what 2"/50mm suspension should I install in my jimny, Old Man Emu (OME) or Trailmaster (TM) and why?
Have a good day,
CM
Have a good day,
CM
- supergaz
20 Feb 2011 18:45 #11875
by supergaz
Replied by supergaz on topic Re: Supension: OME or Trailmaster (2 / 50mm)
Welcome to Bigjimny. Better you get your credit card ready for the jimny thing! The bug bites once you start modding.
- Canoodle Moose
21 Feb 2011 18:54 #11944
by Canoodle Moose
Replied by Canoodle Moose on topic Re: Supension: OME or Trailmaster (2 / 50mm)
...could it be that nobody want's to comment on the question here:
So, what 2"/50mm suspension should I install in my jimny, Old Man Emu (OME) or Trailmaster (TM) and why? :dry:
Have a good evening,
CM
CM
21 Feb 2011 19:14 - 21 Feb 2011 20:09 #11950
by dirtydogz
2002 JLX Soft Top
Replied by dirtydogz on topic Re: Supension: OME or Trailmaster (2 / 50mm)
If you use your jimny everday on the road go for the trailmaster comfort version form big jimny.
If you use it off road a lot go for the sports version.
Hope this helps.
DIRTYDOGZ.
Hope this helps.
DIRTYDOGZ.
2002 JLX Soft Top
Last edit: 21 Feb 2011 20:09 by dirtydogz.
- Canoodle Moose
22 Feb 2011 05:53 #11986
by Canoodle Moose
I will only use the Jimny for the 10Km to my hunting grounds and the partially extreme terrain there. We have an altitude difference of 200m, steep forrest and wet areas. Since I live in Austria, we have all surfaces from forrest ground to mud, snow and ice.
For pure road use I have two other cars.
22 Feb 2011 06:56 - 22 Feb 2011 11:24 #11989
by dirtydogz
2002 JLX Soft Top
OK then go for sports version its better for off road.
Have a look at this on BITS4VITS if it help.
www.bits4vits.co.uk/store/jimny-gets-a-t...r-lift-/blog_58.html
BIG JIMNY also sell Trail Master.
Fit some 205/75/15 MAXXIS 753 BRAVO M/T form CAMSKILL.
www.camskill.co.uk/products.php?plid=m26b0s1680p51799
I have these tyres fitted on 7x15 modules with 20 mm offset,with just 32 mm spring spacers from BITS4VITS with no rubbing on the wheel arches.
HOPE THIS HELPS.
DIRTYDOGZ.
Attachment DSCF1305.JPG not found
HOPE THIS HELPS.
DIRTYDOGZ.
2002 JLX Soft Top
Last edit: 22 Feb 2011 11:24 by dirtydogz.
Time to create page: 0.238 seconds
