jimny leather softtop
- prosnooker147
- Visitor
19 Feb 2011 23:39 #11822
by prosnooker147
jimny leather softtop was created by prosnooker147
well ive just spent the last 45 mins dropping the softtop on my jimny!!!!!! help what plonker designed
it . its the pram type with zip out side windows , zips were a bit stiff not been apart for a while i would guess
anyway took out side windows first ,then back window , then unclipped it from inside released two roof
toggles, folded back great. took about 5 mins not bad for first go.
then the fun started pulled up pram section refixed clips on roof tried to put in first window couldnt
join the zip together on side windows ,would imagine its better on a hot day but suspect the leather
has stiffened up with age ,
can i buy a new cover without zips that just folds ?
any advice were im going wrong please
if i cannot solve this i may have to revert back to my mx5 and my springer spanials not to keen
not much leg room ha-ha
19 Feb 2011 23:53 #11823
by dirtydogz
Try a monsoon soft top 2mins fold down, 2mins to put back up.
www.monsoon4x4.co.uk/index.htm
2002 JLX Soft Top
Replied by dirtydogz on topic Re: jimny leather softtop
Attachment DSCF1314.JPG not found
Attachment DSCF1265.JPG not found
2002 JLX Soft Top
- prosnooker147
- Visitor
20 Feb 2011 00:35 #11827
by prosnooker147
Replied by prosnooker147 on topic Re: jimny leather softtop
hi thanks for the reply , will it fold away neat behind seats, and will it require a lot of work to fit
can you get it in blue ,
sorry for all the questions
i will be buying one in next few weeks thanks again mate cheers
20 Feb 2011 14:29 - 20 Feb 2011 15:02 #11840
by dirtydogz
2002 JLX Soft Top
Hi Prosnooker147
1) You fold the side on to the roof and fold it down like your old soft top.
2) You will need to ring monsoon on the colour of the top.
3) It takes about 4 weeks for a one off top to be made.
Hope this helps you. www.monsoon4x4.co.uk/images/Fitting%20In...ng%20Instruction.pdf
Fitted my soft top in about 3 hours+3 cups of tea.
DIRTYDOGZ.:woohoo:
DIRTYDOGZ.:woohoo:
2002 JLX Soft Top
Last edit: 20 Feb 2011 15:02 by dirtydogz.
The following user(s) said Thank You: prosnooker147
20 Feb 2011 16:18 #11849
by facade
Replied by facade on topic Re: jimny leather softtop
You will likely find that a smear of silicone or vaseline on the zips, coupled with warmer weather will sort out your own top. The plastic is not very flexible in low temperatures.
20 Feb 2011 20:26 #11892
by wildfire
Replied by wildfire on topic Re: jimny leather softtop
I have found silicon spray used very liberally works well, they clog up with road dust. The main issue i have is that the zip on the rear window is slowy coming away from the material.
