Kingpin Bearing Grease?
- JonathonMarshall
- Premium Member
- Thank you received: 2
15 Feb 2011 22:24 #11602
by JonathonMarshall
Kingpin Bearing Grease? was created by JonathonMarshall
Tackling this on saturday, what grease do i need as the how-to just states 'grease'. Thanks for all the bits Martin, hope its not too much of a pig to do!
- vitara_mad
15 Feb 2011 22:46 #11603
by vitara_mad
Replied by vitara_mad on topic Re: Kingpin Bearing Grease?
16 Feb 2011 07:40 #11607
by mcjimny
Replied by mcjimny on topic Re: Kingpin Bearing Grease?
You need proper cv grease in the swivels, the dark grey stuff. I used the normal grease before that says its suitable but it doesn't hold up as well.
It should be labelled as cv joint grease (something like that) as the normal stuff states cv on the front too.
The following user(s) said Thank You: JonathonMarshall
- JonathonMarshall
- Premium Member
16 Feb 2011 07:42 #11608
by JonathonMarshall
Replied by JonathonMarshall on topic Re: Kingpin Bearing Grease?
Cheers mate and i think i'll get some of that LM grease anyway Vit Mad as it'll never come it wrong....anyone give any hints/tips that aren't in the how-to?
16 Feb 2011 14:53 #11619
by mcjimny
To get the bearing race's out, if you haven't got access to a welder to do as martin has use a small cold chisel or punch against the lip of the race to tap them out. It is a small lip but if you tap all round it soon moves, just be careful not to damage the swivel itself.
Get some disposable gloves for packing the cv and hub!
- bryandenham
16 Feb 2011 17:21 #11624
by bryandenham
Replied by bryandenham on topic Re: Kingpin Bearing Grease?
hiya,
if you are only changing the kingpin bearings you DON'T need to dismantle the hub.
Remove vacuum pipes, remove caliper and hang out of way, no need to disconnect brake pipe.
Remove large seal, (ring of bolts).
Remove kingpins, eight bolts, four top, four bottom.
Draw off complete hub and half shaft assembly.
ALWAYS replace small internal oil seal.
Knock out bearing tracks, gently with a small cold chisel, easy but fiddly.
Clean carefully.
knock in new tracks, (the right way round !), careful.
fit bearings, LOTS of grease.
replace small seal.
put everything back together.
Job done, half an hour each side !!!!!!
I ALWAYS use waterproof grease on the king pin bearings and before any clever dick says all grease is waterproof, its not it can emulsify with water. Water pump or underwater grease is easily obtainable and completely solves the problem of water causing the kingpin bearings to rust.
Only use the correct driveshaft coupling grease on the couplings though because it is high pressure grease and is also anti fling.
If you are an engineer then a grease nipple can just be squeezed in but you do need to know what you are doing.
Hope thats a bit clearer than mud
all the best Bryan D
Clean carefully.
replace small seal.
Time to create page: 0.943 seconds
