New Jimny Owner! Flashing 4WD Light!? Pics!
  • Gaz-M
02 Feb 2011 09:56 #10804 by Gaz-M
Hi folks, just bought a Jimny so a new member on here! :)
Just realised in 4WD the light flashes after around 20 seconds. Seen ive to check vaccum hoses and found 2 rusted through pipes. Replaced these with brake piping (Pressuming thats sufficient?) and problem still there.
Someone previously appears to have been mucking around with vaccum stuff under battery and has a vaccum pipe missing from a grey solenoid (Unless its an exhausting port?) and the same solenoid is loose and has had its wiring extended.
Heres a few pics of said bits, does all appear connected as it should? Any common faulty parts?
If anybody could compare that would be greatfully appreciated. Just so i know everythings where it should be!
Heres a pic of the wee beauty!
02 Feb 2011 10:04 #10807 by mlines
For instructions and "compare" pictures take a look here...
www.bigjimny.com/images/documents/Check_the_vacuum_system.pdf
Then when you get cheesed off with playing with them then look here...
www.bigjimny.com/images/documents/fitting_SJ_manual_hubs.pdf
  • Gaz-M
02 Feb 2011 12:01 #10824 by Gaz-M
Perfect thanks!
I actually have a set of Vitara manual hubs ive just reconditioned if they fit the same?
Also, fitting manual lockers wouldnt solve the flashing light which would drive me insane, so how would i go about fixing that?
Cheers!
Time to create page: 0.494 seconds
