Guinea Pigs required!
02 Feb 2011 09:10 #10799 by mlines
Guinea Pigs required! was created by mlines
Following on from a conversation with Bryan from this forum I have a possible new product lined up.
I need two volunteers who are happy to try out a small modification. You must:
1. be prepared to try it out immediately - (no "I will give it a go during the summer" answers!)
2. Have reasonably new Kingpin bearings - (This is not a cure for worn ones)
3. Have an element of "wobble" or lightness about the steering - (But not worn panhard rod bushes!)
4. Supply me pictures of the installation
5. Drive on the road regularly
In return I will send you the parts for free.
  • vitara_mad
02 Feb 2011 09:33 #10800 by vitara_mad
Replied by vitara_mad on topic Re: Guinea Pigs required!
put my name down if you dont mind im all for testing new products & mine is my daily driver so it will get tested right away
atb richard
  • srcars
02 Feb 2011 09:41 #10801 by srcars
Replied by srcars on topic Re: Guinea Pigs required!
Mine to is a daily driver which had no wobble until I fitted small muds (which were new and balanced) I now suffer a very small amount of wobble between 35 an 40 mph :whistle:
  • gazert
02 Feb 2011 09:44 #10802 by gazert
Replied by gazert on topic Re: Guinea Pigs required!
Hi Martin,
I have 3 week old kingpins.
I have just modded the car as u can see.
I drive the car 45 miles 6 days a week.
I would me more than willing to help out as much as I can.
Ps can u fit re location brackets to front shocks?
02 Feb 2011 10:01 #10806 by mlines
Replied by mlines on topic Re: Guinea Pigs required!
Ok - three people in the trial. If you can send me your postal addresses via PM that will be great.
The rear shock brackets do not fit the front. Various suppliers can supply extensions for the front, these fit on the top of the shock and are therefore "brand dependent" as the threads on the top vary depending on brand.
However, on Friday I will receive the first prototype of a Front Shock re-positioner, this will fit on the bottom and will therefore fit all types of shock. It will also be "bolt-on" (I am sure someone will point out that you can move your front shock easily if you can weld).
If this works then it will form an "instant boost" or "perk me up" kit I am putting together in conjunction with Bits4Vits Spring Spacers. Will hoepfully be trialling it on mine shortly
  • vitara_mad
02 Feb 2011 10:11 #10809 by vitara_mad
pm'd you my details martin ;)
Time to create page: 0.110 seconds
