Symptoms of a failed kingpin bearing?
01 Feb 2011 21:44 #10787 by JonathonMarshall
Just wondering because there was an advisory on the drivers front kingpin bearing on the MOT. I think it may have gone but i'm wondering what the evidence of that would be, noises, feeling etc etc. Cheers all :)
  • gazert
01 Feb 2011 22:00 #10788 by gazert
Replied by gazert on topic Re: Symptoms of a failed kingpin bearing?
If u jack the wheel off the ground and grip the wheel top and bottom, then waggle. If there is play its the kingpins.
  • uau242
02 Feb 2011 12:18 #10827 by uau242
Replied by uau242 on topic Re: Symptoms of a failed kingpin bearing?
Hi
Are the kingpins generic? Does it depend on year or place of manufacture at all? I've also noticed that there is a KOYO kit and FAG kit? Is it just a case of different manufacturers?
Thanks
02 Feb 2011 13:11 #10831 by mlines
All bearings with the same part number (30302 in this case) should be the same. However, there have been reports in the past that some variants don't fit.
Therefore I stock Koyo, which are the brand you get if you go to the Suzuki dealers, part with an arm and a leg, and get a Suzuki branded one. When you open the packet it says Koyo.
It is not always possible to get Koyo so you will see other brands that fit (such as FAG) appearing in the shop.
The ones to really avoid are very cheap "white box" Chinese ones. They come in plain white boxes anda re really cheap but I have hear reports that they last a matter of minutes in the rough stuff.
Time to create page: 0.144 seconds
