Exhaust fixings, thread size?
- Jimaroid
02 Feb 2011 13:13 #10832
by Jimaroid
Replied by Jimaroid on topic Re: Exhaust fixings, thread size?
Yeah, here's where I'm confused. I was convinced it was an M10 thread but the M10 nuts I borrowed from something else didn't fit. I've gone and got some new nuts just in case the borrowed nuts weren't actually M10 at all but I'd swear they are. We'll see.
- vitara_mad
02 Feb 2011 14:05 #10835
by vitara_mad
Replied by vitara_mad on topic Re: Exhaust fixings, thread size?
you have confused me a little here :huh:
has your exhaust got captive nuts welded on it & you looking for the right size bolt to fit them ????
if thats right you will need m12 x 1.25 thread bolts as standard m12 bolts are 1.5 pitch & will not fit the nuts
- Jimaroid
02 Feb 2011 14:51 #10838
by Jimaroid
Other way around, I have bolts welded to the flange of the back box.
Like this order,
-BOX-|= |:
- pipe
| flange
= bolts x 2
: nuts x 2
Like this order,
-BOX-|= |:
- pipe
| flange
= bolts x 2
: nuts x 2
- Nelson83
02 Feb 2011 14:57 #10840
by Nelson83
Replied by Nelson83 on topic Re: Exhaust fixings, thread size?
I found the M12s too big, and the M10s slighty too small, so guessed it was the pitch but I couldnt be arsed to double check the pitch size of the nut so just forced the standard M10s on, they just mangled the bolt thread, but went on a treat - i know they wont come off unless i take the grinder to them now :whistle:
- vitara_mad
02 Feb 2011 16:28 #10843
by vitara_mad
oops sorry just noticed i put m12 i ment to put m10 x 1.25 thread
- bigoffroader
05 Feb 2011 18:48 #11035
by bigoffroader
Good thing is that’s what I do for my day job
Replied by bigoffroader on topic Re: Exhaust fixings, thread size?
This is correct M10 x 1.25 basically M10 fine thread I had the same problem so had to make some as I needed them ASAPvitara_mad wrote: i ment to put m10 x 1.25 thread
