a few jimny issues
29 Jan 2011 09:46 #10510
by facade
Replied by facade on topic Re: a few jimny issues
The bottom hose is supposed to be stone cold this weather, if the gauge reads near half way the engine is normal.
I have a picture of the heater levers on mine, likely it is set to half heat and screen/feet
Attachment heater_2011-01-29.jpg not found
- jimny1971
- Visitor
29 Jan 2011 11:51 #10524
by jimny1971
Replied by jimny1971 on topic Re: a few jimny issues
hers the pic of the heater controls from mine the 1st one its on hot is that right
second pic is the heater above is this 1 ok?
3rd pic is the wire from the gear box which is for the reverse lights
29 Jan 2011 13:01 #10529
by kirkynut
Replied by kirkynut on topic Re: a few jimny issues
I was nearly right, I knew I read something about something being kicked off!
Good luck then, I'm all out of suggestions I'm afraid then!
- paulnb57
- Visitor
29 Jan 2011 21:06 #10570
by paulnb57
Replied by paulnb57 on topic Re: a few jimny issues
Just a thought regarding the handbrake light. My guess is that something else is earthing through the hand brake warning light circuit, like when you have a bad earth on an indicator and a brake light (or similar) flashes on and off dimly with the indicators. God knows how to suss it though!!.........Poor earth somewhere??
Good Luck
Paul
Good Luck
Paul
30 Jan 2011 12:01 #10610
by kirkynut
It could be a break in the insulation to the live wire going to the switch causing it to earth somewhere else to vaguely complete the circuit, hence the dimness. That will be a bugger to find though!
- jimny1971
- Visitor
08 Feb 2011 18:51 #11189
by jimny1971
just a update guys after a good root under the bonnet i found where the reverse lights had been disconnected plugged the wires together and works a treat
had brake light has gone off now after a mess with the wiring loom
heater still same
heater still same
