clutch problems
- vitara_mad
25 Jan 2011 17:05 #10344
by vitara_mad
clutch problems was created by vitara_mad
me & my bro both have jimny's & both needed a new clutch as they was slipping so we started by doing my bro's first got it all fitted & its still slipping so after alot of head scratching & taking clutch off & back on several times just to make sure we not missed something its still the same & im out of idea's to whats wrong.
the only think i can think of is either the flywheel is worn or the friction plate is not thick enough
does anyone know what the thickness of a new jimny friction plate is & the depth of the reccess on flywheel where the friction plate sits as i presume that is suppose to have that bit of reccess on it it's 2mm on both these flywheels
any help or suggestions will be great as im getting rather annoyed with it now as its a simple job to replace a clutch ive done plenty before on vits & even did my bro's jimny when he first got it
cheers
cheers
25 Jan 2011 18:06 #10348
by MigCooper
Snorkel and plenty of rust to be treated
Replied by MigCooper on topic Re: clutch problems
Did you replace the pressure plate and bearing as well? or just the disk?
- vitara_mad
25 Jan 2011 18:26 #10349
by vitara_mad
Replied by vitara_mad on topic Re: clutch problems
replaced all three parts
- andyw
25 Jan 2011 18:37 #10350
by andyw
Replied by andyw on topic Re: clutch problems
Any chance you've turned the adjustment wheel back to front on the cable, can happen:blush:
Andy
Andy
25 Jan 2011 19:10 #10352
by kirkynut
Replied by kirkynut on topic Re: clutch problems
I've not changed a Jimny clutch but would imagine it has something to do with the adjustment of the cable.
25 Jan 2011 21:50 #10364
by facade
Replied by facade on topic Re: clutch problems
If there is definite free play in the cable and it slips with a new pressure plate and friction plate then most likely the flywheel is worn as you say.
