Spring spacers Q
  • bertbuckie
20 Jan 2011 10:33 #10020 by bertbuckie
Spring spacers Q was created by bertbuckie
Right.... I am still looking into spring spacers for a lift as moneys tight.
I have found a set on ebay which includes front and rear repossitioners but there 1 3/4"
I can only find rear repositioners elsewere including here.
Do you NEED the front ones? ( they look like box section with a hole through it )
I would prefer a 2" lift but cant find the front repositioners anywhere :(
20 Jan 2011 10:52 #10021 by mlines
Replied by mlines on topic Re: Spring spacers Q
Hi,
I am a little confused as you appear to switch between two different products in your question.
1. Spring spacers - these fit on the top of the springs and look like this.....
- I can get these for you for £94.33
2. Shock extenders/re-positioners - these fit on the shock absorbers. The rear ones look like this...
However, we do dot have front ones around at the moment, some prototypes should arrive with me next week.
So to do a lift with spring spacers adds up a bit as you need to look at shock spacers as well, unless you want to risk that your current shocks will cope with a bit more extension?
I think your best best for the cheapest lift is a body lift at present - see www.bigjimny.com/store/index.php?act=viewProd&productId=119
  • bertbuckie
20 Jan 2011 11:09 #10022 by bertbuckie
  • bertbuckie
20 Jan 2011 11:09 - 20 Jan 2011 11:10 #10023 by bertbuckie
Last edit: 20 Jan 2011 11:10 by bertbuckie.
20 Jan 2011 11:12 #10025 by mlines
So those are spring spacers, you will need to consider the effect they will have on your shock absorbers as well
  • DAVE T
20 Jan 2011 11:28 #10027 by DAVE T
Replied by DAVE T on topic Re: Spring spacers Q
bert you have a pm
Time to create page: 0.105 seconds
