spring lift
  • DAVE T
13 Dec 2010 09:58 #7425 by DAVE T
Replied by DAVE T on topic Re: spring lift
cheers dirtydogz
  • Andy
13 Dec 2010 10:04 #7426 by Andy
Replied by Andy on topic Re: spring lift
Baz, have you found that your rear springs have been touching the shocks or have you managed to get away without moving the bottom brackets of the shocks using the repositioners? Andy
  • dirtydogz
13 Dec 2010 10:55 - 13 Dec 2010 10:55 #7429 by dirtydogz
Replied by dirtydogz on topic Re: spring lift
No the spring don't touch the shocks with the 1.5 lift.BAZ.
Last edit: 13 Dec 2010 10:55 by dirtydogz.
13 Dec 2010 17:31 #7474 by Johnniehec
Replied by Johnniehec on topic Re: spring lift
Dirtydogz, one inch body lift? I've not seen one advertised but I was thinking it would be possible with the existing bolts, one inch nylon spacers and re arrange the rubbers, is that what you did?
John.
  • dirtydogz
14 Dec 2010 08:56 - 14 Dec 2010 11:22 #7529 by dirtydogz
Yes i re arrange the rubbers.
Attachment DSCF1154.JPG not found
Attachment scan0005.jpg not found
I used the large rubber at the top,and the bit i cut off under the washer and nut, works out to be about a 1"inch lift, with the spring spacer just over a 2" inch lift.
If you go to technical on page 8 and look for eco spring + body lift this may help.
BAZ.
Last edit: 14 Dec 2010 11:22 by dirtydogz.
Time to create page: 0.228 seconds
