DC to DC charger and standard alternator in a 2016 gen3
- a.dutton@hotmail.com
- Junior Member
- Thank you received: 3
23 Sep 2026 09:00 #265288
by a.dutton@hotmail.com
Hi all. some help please Im currently researching (learning as I go) and putting together a solar set up for my 2016 Jimny. What started as a simple build has become rather more uprated with the wifes demand for a 1800 watt hairdryer capacity ! I now have a 20 amp DC to DC charger and a 100 watt solar panel, to 2 x100ah lithium batteries, 3000 watt inverter.. Now wanting to understand if a 30 or even 40 amp DC to DC charger would be possible without upgrading the alternator. I have no other modifications putting extra demand on the alternator. Without straining the standard alternator would this upgrade to 30 or 40 be ok ? Thanks in advance.
24 Sep 2026 14:10 #265298
by RainerK
Replied by RainerK on topic DC to DC charger and standard alternator in a 2016 gen3
A 30 to 40 A DC to DC charger should be ok.
I had a similar problem and I got a 1kWh Anker powerstation from Anker and the Anker Solix Alternator charger, which actually charges with more than 40A (I think 600W to 800W). This works nicely and the Alternator charger has some intelligence (only charges if the motor is running, only takes excess electricity, …) and can even feed back into the starter battery (which I think is very good but actually did not have to use so far). For me this is a simple setup and if I do not need the electricity, I take the Powerstation out of the car.
The following user(s) said Thank You: a.dutton@hotmail.com
24 Sep 2026 22:34 - 24 Sep 2026 22:42 #265300
Replied by yakuza on topic DC to DC charger and standard alternator in a 2016 gen3
I ran my 30A victron DC-DC charger for a while on the original 70A gen3 generator with no issues. Charging 70Ah agm starter battery and 50 or 100Ah lifepo4.
Could see in the bt app the victron pulling 27A and the battery getting it too. It is the old victron the big Hot one, work just fine.
I swap batteries between the car and trailer. No solar input during the winter here and no Charging below zero either.
I only run a fridge and a heater though, have no need or would ever want any Converter or large appliances.
I have since swapped the gen for a 100A SX4 unit.
Last edit: 24 Sep 2026 22:42 by yakuza.
26 Sep 2026 07:51 #265303
by Busta
Replied by Busta on topic DC to DC charger and standard alternator in a 2016 gen3
Get a portable power station like a Jackery, Bluetti, Anker etc. They are so much more useful than filling your car with wires and batteries. Solar and 12v charging options are easy.
27 Sep 2026 11:30 #265318
For most those ready made batteries are out of the range of the common budget, and for the "other most" to make your own battery and hook everything up is out of the range of common know how.
For me those readymade leisure batteries have expensive functions I do not need like 230V, they work poorly below 0C and charge slow from the car. At least those within my budget.
I could get so much more way cheaper being able to build my own battery and size and spec everything up to my own needs.
Make sure any battery and any load on it have fuses and make sure it is not li-ion wich in a fire feeds it selves with o2 and starts to self ignite at 150C and not 270C like lifepo4.
Also most li-ion have many more cells than modern batteries. more cells, more risk of one having a fault.
