Gen4 mechanical ventilation control
15 Aug 2026 09:28 #265094 by Lambert
Whatcha. My fan makes lots of blowing noises and the direction knob makes things in the depths go clunk especially between screen and cabin. However there's virtually no difference in air speed on the dashboard vents regardless of blowing noises increasing. I have removed and will be ordering a new cabin filter as this one is nasty but it hasn't made any difference to air flow. Before I send the camera down the vent outlet is there anything in particular that could be a known cause. The control cable seems to be intact and does make things move. 2024 lcv.
15 Aug 2026 15:20 - 15 Aug 2026 15:55 #265095 by mlines
Control cable 1 in the picture below controls the main three way air door
It appears as item 19 in the picture below. It has a 3 way operation
Exit 9 are the ball vents on the dashboard ends
Exit 10 is the central vents
Exit 11 is the foot vents
Exit 13 are the side demister vents
Exit 12 is the windscreen
Last edit: 15 Aug 2026 15:55 by mlines.
15 Aug 2026 15:50 #265096 by Lambert
Cheers mate. So I'm not getting that volume of air in those positions. I'll feed the camera down and see what is stuck or blocked or whatever. I can hear the recirculation door move and without the ac recirculation does fog the windows quickly compared with external air mode so I would say that is working. Leave it with me and I'll report any findings. Thank you.
15 Aug 2026 15:56 #265097 by mlines
I edited more into the vents description as it was not clear what some of the other vents do
15 Aug 2026 17:06 #265098 by Lambert
Ok so findings. Camera reveals that the passages are clear. The levers are able to move from one extreme position to the other. However the degree of movement between any 2 or 3 adjoining positions is negligible. It's as if either the cable is stiff or the door pivots are. I'm wondering if there's some aerosol lube I could introduce into the intake that could free it off without taking the whole thing apart?
16 Aug 2026 09:13 #265099 by Lambert
Was thinking about this last night. Should the control end of the cable will the rotary control be able to push as well as pull the cable only looking at it it's not a proper Bowden cable but a sheathed wire that looks like it could be pushed. That then might suggest that something on the back of the rotary control has failed like a grub screw backed out? First issue how do I get to the back of the rotary control cluster because it's different from the gen3 and I have yet to delve that far into it. Secondly does anyone have a diagram of what the back of the rotary controls ought to look like?
Time to create page: 0.700 seconds
