Headlight lenses
11 Jun 2026 07:37 - 11 Jun 2026 07:39 #264662
Replied by yakuza on topic Headlight lenses
Found another seller on aliexpress that have the brakckets and sorrounds only at 143€.
Then I can buy E-marked standard 7" Hella or something lamps that will pass MOT.
edit. cant change to leds on a non led car here in Norway I think.
Last edit: 11 Jun 2026 07:39 by yakuza.
- Thank you received: 1992
11 Jun 2026 08:07 #264663
Replied by Lambert on topic Headlight lenses
Interesting. Like the idea of branded elements.
11 Jun 2026 08:16 - 11 Jun 2026 08:18 #264664
by RainerK
Replied by RainerK on topic Headlight lenses
Not directly on the headlight plastic exchange/repair: Maybe you could use H4 LED bulbs, also in Norway? In the EU there are some that are certified for the JB43 headlights with the E13 9328. They are produce by OSRAM, e.g., H4-LED SP 450.
Last edit: 11 Jun 2026 08:18 by RainerK.
11 Jun 2026 15:30 #264668
yes, I know.
Osram and one or two others as well.
Won't get properly dark here until September now, so Ill look into this come autumn.
But the lenses, looked at my spare lamps a few years back and found I would not bother considering prices for the lenses and the amount of work changing them..
11 Jun 2026 16:18 - 11 Jun 2026 16:18 #264669
by MattHE
Replied by MattHE on topic Headlight lenses
My lense covers also go slightly cloudy (2006 VVT), so I re-polish them by hand once or twice a year.
Method: First pass with superfine wet & dry paper used very wet, in small circular movements over the whole lense surface. I start with 2500 grit and only go to 2000 grit if the lense is really bad (like after winter). Then clean off off and dry to check progress, repeat if necessary. Then I use Duraglit wadding (the brass version, not the silver) to polish, again in small circular motions. Buff off with a soft dry cloth to check progress, repeat if necessary. Stand back and admire! It wont be like brand new lenses, but this option always works for me.
As with all these things - test on a small area first, and always start with the finest paper first - scratches will need work to buff out. I learned about the Duraglit thing 45 years ago at design college when invisible jointing pieces of clear acrylic.
Best,
Matt
Best,
Matt
Last edit: 11 Jun 2026 16:18 by MattHE. Reason: spelling
Time to create page: 0.223 seconds
