Aluminium transfer guard.
07 Jun 2026 09:09 #264615 by Lambert
Just quickly are the gen3 transfer guards all the same between left and right hand drive versions? I've found an aluminium one made in France but sold through an English language page. It just doesn't make mention of being specific to lhd. I've been looking for a while and it is the first one I have seen and being aluminium it's about half the weight even though it's 8mm.
07 Jun 2026 14:35 #264620 by fordem
Replied by fordem on topic Aluminium transfer guard.
I don't think the position of the steering wheel will matter for a transfer case guard, the t/case is far enough back that the steering components are unlikely to be come into contact with it.
07 Jun 2026 15:27 #264621 by yakuza
Replied by yakuza on topic Aluminium transfer guard.
Aluminium should be isolated from the steel to avoid corrosion.
And I would think 3mm steel or 5mm aluminium would suffice.
But guessing there are less reinforcment bends when aluminium? And more costly?
07 Jun 2026 16:04 #264622 by Lambert
Replied by Lambert on topic Aluminium transfer guard.
Allegedly there may be some exhaust difference? They are asking 199 for the aluminium one. There is also a stainless steel one from a different supplier which is 2mm and 172 from memory. That mild steel one I took off is like 5mm and quite a heavy old Hector which is why I took it off, it's like 10 kg give or take, strong though.
08 Jun 2026 13:15 #264631 by RainerK
Replied by RainerK on topic Aluminium transfer guard.
This one is aluminum but not 8mm, however in picture #2 you see how it mounted on a LHD. Maybe this helps.
www.horntools.com/products/unterfahrschu...fj-verteilergetriebe
08 Jun 2026 16:37 #264635 by Lambert
That's interesting. 3kg is good and I wouldn't expect to sit the car on it's more an audible warning. Hmm lots to think about.
Time to create page: 0.193 seconds
