Fails to start and sometimes stalls in left hand cornering.
24 May 2026 08:41 - 24 May 2026 09:14 #264483
by Keflady
Hi
My 2002 Suzuki Jimny has an intermittent problem. Sometimes she won't start when cold, sometimes won't start when hot. Has stalled at left hand corners, then it won't start for ten minutes or so then fires up no problem. Will idle sometimes with no problem but will occasionally stall, very rarely can feel it missing when driving.
Spanish cabriolet model.
Any ideas?
Any ideas?
Last edit: 24 May 2026 09:14 by Keflady. Reason: Extra info
- Thank you received: 1999
24 May 2026 15:16 #264487
Replied by Lambert on topic Fails to start and sometimes stalls in left hand cornering.
First off is it persistently showing any engine warning light? Have you had it read for fault codes, It does sound like it could be sensor related.
- major clanger
- Junior Member
- Thank you received: 7
24 May 2026 19:27 #264489
by major clanger
Replied by major clanger on topic Fails to start and sometimes stalls in left hand cornering.
Sounds typical of a failing crank position sensor. Symptoms common to most fuel injected vehicles with that fault.
25 May 2026 06:10 #264493
by Keflady
Replied by Keflady on topic Fails to start and sometimes stalls in left hand cornering.
Hi
Engine warning light only comes on when it stalls, not on failing to start from cold. Hubby has lost his code reader, ordering a new one. Thank you for your response.
25 May 2026 06:12 #264494
by Keflady
Thank you, this is where hubby was going next, has already replaced fuel pump/filter, plugs etc.
05 Jun 2026 04:25 #264590
by Keflady
Thank you, new crankshaft sensor and all is good!
Time to create page: 0.492 seconds
