Roof rails on a non roof rail edition
27 Feb 2026 20:06 #263907 by Liam205
Hey chaps, I’m looking at puttting a roof rack on using the mounting points for the rails, problem is that my Jimny never had roof rails! Anyone know if it’s an easy job to remove the trim and access the fittings without destroying the roof?
pictures included show the black trim covering the rails
23 Mar 2026 21:38 #264074 by Darthblaker7474
TL:DR It's gonna be a pain in the arse.
Unlike a lot of other cars, Suzuki in their infinite wisdom decided that the roof rails and their mounting points should be attached on the side outer skin, not the via the roof gutters.
You'll need 4 of these plates with the studs on them, but to actually fit them to the vehicle you'd either need to cut out the outer skin, put them on and weld them up. Or you could go inside after removing the headliner, cutting out the inner skin, etc.
I've got a spare roof in the garden which I'll get some pics of if it doesn't make sense.
Time to create page: 0.209 seconds
