1999/2000 Jimny immobiliser issue?
07 Jan 2026 19:01 #263319
by arthursc
1999/2000 Jimny immobiliser issue? was created by arthursc
We’re having issues with my Jimny. Sat for six years and not started. Battery change and she started and ran.
24 hours later came to start and wouldn’t
engine cranks but no spark. Fuel pump primes and pumps fuel, all fuses checked and ok. So this is what I have done so far;
Changed all ignition coils (new)
Changed CAM Sensor (new)
fixed broken wire under the engine fuse box for the injection (15amp)
have had the key checked and key coil is good. But engineer could not read the Immobiliser/ECU to read the key code.
3 different people with varying ages of ODB readers unable to read keys or reprogram key.
ODB comes back with no errors but BMC can’t read key code.
I suspect it’s the immobiliser. ECU IS 5H version. Immobiliser is standard I70E0
thoughts please.
thoughts please.
07 Jan 2026 23:34 #263324
by fordem
Replied by fordem on topic 1999/2000 Jimny immobiliser issue?
First - if there is an immobilizer fault there should be some sort of dash warning light to indicate this, look at the dash lights & check your owner's manual
Second - 1999/2000 will usually not respond to an OBDII reader, but can be diagnosed using the check engine light and a jumper wire in the monitor coupler.
What lights are on when you switch the ignition on before trying to start the engine - do you have at least the oil pressure light, the charge light and the check engine lights?
08 Jan 2026 12:51 #263327
by arthursc
Replied by arthursc on topic 1999/2000 Jimny immobiliser issue?
All dash lights as should be when turned on. “Check engine” light flashes indicating from the manual an issue with key or immobiliser.
- Thank you received: 1988
08 Jan 2026 14:30 #263329
Replied by Lambert on topic 1999/2000 Jimny immobiliser issue?
As suggested bridge the diag port and read the flashing code.
08 Jan 2026 15:38 #263331
by arthursc
I have absolutely no idea how to do that, what pins to “bridge”.
some assistance in how to do this would be greatly appreciated.
08 Jan 2026 16:55 #263333
by fordem
Time to create page: 0.192 seconds
