Long term review
- Thank you received: 1982
01 Jan 2026 04:34 #263233
Replied by Lambert on topic Long term review
That is interesting, being the lcv it has filament lights and they are good but I was thinking about putting a set of ring 200% in the same as temeraire because on dip they are a less blue colour but on full they are almost like having an extra light bar.
As for satnav and more generally the infotainment system I'm that tied to using my phone for nav and Bluetooth music that if I had one with the touchscreen I would have replaced it with the poverty spec one with the buttons that the yellow one came with anyway. But that said it is highly unlikely I will get lost enough on my way between home and either work to need a nav in the yellow one anyway.
02 Jan 2026 13:50 - 02 Jan 2026 13:51 #263247
by Gadget
Replied by Gadget on topic Long term review
I've only owned a Gen4 so can't compare to the earlier generations, but for me the looks of the Gen4 are one of its strongest points. I'd have never bought a Gen3 as they look too 'generic 90s Japanese car' for me, whereas the 4 is an absolutely iconic bit of design.
The Gen4 definitely has its flaws, most of which can be addressed with mods, but some remain - here's my list of those I can remember.
- AEB is the biggest annoyance, but not a Jimny or Suzuki issue, just a legislative one. Everything modern has to have it, it sucks. At least you're able to permanently disable the lane keeping, even if you do have a permanently lit warning light as a result.
- TPMS drama queen - maximum panic and all the warning lights when 1psi under pressure. I've actually got a TPMS delete gizmo in case I ever need it, but overall I find TPMS useful enough to keep it.
- Driving position/seats are ok, but as someone with long legs I've always found the seat squab a bit unsupportive under the thighs and would have loved an adjustable reach steering column. Still contemplating spending a zillion pounds on a brand new Recaro drivers seat.
- LED headlights are too good, I get flashed by other drivers all the time, despite having had them checked at each service.
All the other minor flaws I've already fixed.
- No one-touch up/down on all windows - fixed with aftermarket doodad.
- Door open beep - fixed by disconnecting plug
- No variable intermittent wipe - fixed with Swift wiper stalk
- Static shocks when getting in/out - fixed with Escape Gear canvas seat covers
- No digital speed display, no temp or voltage gauge - fixed with OBD2 display
- No volume knob - fixed with new head unit
Last edit: 02 Jan 2026 13:51 by Gadget.
- Thank you received: 663
02 Jan 2026 17:10 #263248
The thing is, my car has had two services at the main dealers and an MOT since then and it hasn’t been commented on at all.
I might have asked this before, but which OBD display did you buy? I did think about one, but there seemed to be mixed views on whether they would work with a UK Jimny Gen 4.
Ta
Robin
Replied by DrRobin on topic Long term review
My headlamps were set correctly, but I got flashed at all of the time, so I just dropped them down a bit, so they didn’t dazzle. They still illuminate the road ahead very well on dip, in terms of distance and light level, probably better than most vehicles I have owned/driven and there is no difference at all on main beam.- LED headlights are too good, I get flashed by other drivers all the time, despite having had them checked at each service.
Ta
Robin
03 Jan 2026 11:01 #263253
by 300bhpton
Replied by 300bhpton on topic Long term review
You should be fine with LED lights properly adjusted. They are easy to adjust yourself too. Never really been flashed in mine in over 5 1/2 years and 40,000 miles. The cut off is very good in the beam profile, so you can easily see if your lights are too high and shining in the faces of oncoming traffic. You might just need to point them a little more to the left...
03 Jan 2026 20:18 - 03 Jan 2026 20:21 #263256
by lightning
Replied by lightning on topic Long term review
Reading this thread it's very similar to the old/new Defender thread over on the LR forum.
Except that the new Jimny is a lot more like the old model, than the new Defender is to the old one.
Personally l think the new Jimny is a masterpiece and l wish Land Rover had done a similar thing with the old Defender.
There's almost nothing l don't like about our 2020 Jimny SZ5, the satnav is a bit clunky (although you can mirror a phone which solves the problem) and it's not full time 4wd.
The ride quality is remarkable for a small live axle 4x4. lt deals with poor road surfaces much better than an old Defender, and the steering is also very good for the type of vehicle.
We don't have any issues with the placement of window switches etc or the driver aids, which have never intervened on ours. l've got the lane assist permanently turned off.
We've travelled all over the country in the Jimny and had no issues at all, it's a bit thirsty for such a small vehicle but again only to be expected.
You have to be careful with the part time 4wd. l had it in 4wd to get on/off a muddy verge, coming off the verge l had to do a U-turn, l moved the lever to disengage the 4wd but as the wheels were on lock it stalled in the middle of a busy road and would not move. l couldn't get it out of 4wd and it wouldn't move. Eventually l straightened the front wheels and then it went into 2wd, fortunately there was nothing coming or we could have been in trouble.
Last edit: 03 Jan 2026 20:21 by lightning.
04 Jan 2026 05:01 #263257
I try very hard not to notice the exterior design and fortunately I don't have to look at it while I'm driving it. To me it's willfully retro which I don't like on any car as I think it's lazy. Add to that that with a new set of bumpers and lights it will pass as a G wagon, a Defender, a Renault 5, a Lancia Delta, a Daihatsu Fourtrak, or an SJ among others and that to me says it's none descript it's not itself it's not original. Yes it a world of platform sharing blobs designed to meet pedestrian safety standards by basically the same cad package yes the new jimny stands apart but it could have been unique instead of a mash up of old design ques.
Time to create page: 0.176 seconds
