2001 jimny autobox waterproofing
17 Dec 2025 02:00 #263100 by Jackw06
So other day I took my 2001 auto Jimny’s to a pay and play snorkel all extended axel breathers but completely forgot about the box and have more than likely killed it going through deep water am going to purchase another box any suggestions on what to do to waterproof the box so I don’t kill another
17 Dec 2025 06:20 #263104 by Lambert
I'm aquaphobic so intentionally try not to get my wheels wet so I can't really comment but I'd have thought there was some kind of breather for the box that could be extended unless it just uses the dipstick tube which wouldn't be as easy to seal or extend. I'm sure one of the water babies will have a better idea
The following user(s) said Thank You: Jackw06
17 Dec 2025 13:39 #263110 by fordem
There is a breather, which can be extended, but if you get in deep enough water can also enter via the dipstick/fill tube.
18 Dec 2025 03:15 #263122 by Jackw06
Would I be able to just seal the dipstick in as it will only be used for pay and plays once or twice a month and the site is less than 5 miles away so unlikely to do the millage for a box service
18 Dec 2025 03:36 #263123 by Jackw06
Also to mention I did drain the fluid soon as I got home did not seem to be any water or sludge in there
18 Dec 2025 04:12 #263124 by Lambert
If the fluid was clean then I might suggest you got away with it and changing the box is overkill if it's still selecting the gears and not slipping when it shouldn't. If you have already got another box one it will show you where the breather is and two it's there as a spare for if and when it's needed.
