Front wheel turn angle display
27 Nov 2025 03:22 #262926 by ASG
Any thing available to buy like this
27 Nov 2025 04:25 #262927 by Lambert
Welcome to the forum. I'm not sure if you can get something like that for the jimny but my prado comes with it and honestly it's a bit of a gimmick, I've tried it a couple of times and really i find it a bit distracting. After all on flat ground you can tell you are turning and in ruts maybe but you can usually tell if it's trying to pull or climb against the side. It's also one of the things I had to have done on the warranty on my prado.
The following user(s) said Thank You: ASG
27 Nov 2025 11:20 #262929 by 300bhpton
I don't know if that info is available from the OBDII port? If not, you'd need to mount some sensors on the vehicle.
Although, apart from being a gimmick/gadget, I can't say I honestly understand what the use case would be for having this? In the example in the video I also could not understand what the numbers meant, or was one of them engine rpm?
27 Nov 2025 12:23 #262930 by yakuza
27 Nov 2025 19:51 #262931 by facade
I assume you write it yourself and use a PIC, ardueno or something, you can interrogate the steering angle sensor via OBD (on a gen 4, gen 3 has proper sensible hydraulic power steering and doesn't have one unless it has skid mitigation or whatever it is called)
Looking at the video, what do the random numbers mean?
27 Nov 2025 19:56 #262932 by mlines
Do you know the can-id for the sensor?
