Quaife installation
- a.dutton@hotmail.com
- Thank you received: 3
21 Oct 2025 09:18 #262387
by a.dutton@hotmail.com
Quaife installation was created by a.dutton@hotmail.com
Hi all.
Following my last post and after lots of head scratching I have ordered and received Quaife's for the front and rear. I am however going around in circles trying to find an installer. Quaife tell me go to Jimnybits , Jimnybits say they cant help with installation or recommendations. Helpful replies like any "gearbox reconditioner can do it" , have turned out to be they may be able to do it but not willing to do so when Ive asked ( or I'm still waiting for promised reply )
Has anyone on here actually had a quaife installed by someone that they can recommend ? I'm happy to travel within reason to have a trusted installer (im in the North west). A jimny mechanic offered to take the diff out so that I could take it to a gearbox place to have the install done, then hed put it back in, This is the closest ive got. Finding the elusive gearbox place proving to be more challenging. Id prefer to drop off the car and have it done in one place but if I need to do the solution offered by the mechanic then Ill do that.
The above mechanic said he doesn't want to do it because it "wont last 5 minutes if not set up correctly". Given the price of these Im nervous to use someone without recommendation. Am I overly worrying ?
Any help would be greatly appreciated.
Thanks
Andrew
Thanks
Andrew
21 Oct 2025 10:51 #262389
by fordem
No you're not.
I'm not in the UK so unable to assist with a recommendation, but, perhaps rather than hunting for a mechanic or gearbox place, look for an outfit that works with differentials.
Setting up the hypoid gears in a differential requires specialist tools & experience, if it's not done right, you end up with a noisy axle, and you only get one chance to get it right. Get it wrong, and by the time you know it's wrong, it's too late to fix it. By the way, it's not the differential that's going to be damaged, it's the ring & pinion gears.
Yukon Gear Instructions.
Just to give you an idea of what's involved, the link above will let you download a manual that shows the process for installing new gears on an existing differential, you should not need to do the pinion depth or pinion bearing pre-load adjustments, unless you're changing the pinion bearings - the final backlash & carrier bearing preload is where your focus would be.
Replied by fordem on topic Quaife installation
No you're not.
The following user(s) said Thank You: a.dutton@hotmail.com
21 Oct 2025 12:09 #262390
Replied by yakuza on topic Quaife installation
I am kind of stupid so I done this myself. Sometimes by feel even but then I had a load of spare SJ diffs (allmost same as rear jimny) to swap as they broke. But they did not. I have never touched the crush sleeve and pinion pre-load though.
The last time I did the ARB on my jimny I was lucky enough to borrow the micrometer to measure backlash and other tools like a torque wrench so got it done kind of properly. Should have checked the contact pattern I guess but sounds and works fine.
I still might have done something stupid as it leaks air a bit now.
Where I live there are 4x4 specialists that can do the diff.
Most basic mechanically knowledged owners can remove the diff, put it in a box and send it to a specialist and, get it set up properly. Maybe where you live too?
Money thrown at a specialist to set it up is money well spent.
21 Oct 2025 13:43 #262393
by fordem
Just my opinion, Suzuki's "drop out" style third member differentials are relatively easy to work on, you still need to have a fairly substantial bench & vice, but you're not under the vehicle.
They also have screw type adjusters, so if you're just swapping in a locker (or even a Quaife), the back lash & preload adjustments are way easier than if you had to remove & replace to change out shims.
A dial gauge is what would normally be used to measure the backlash.
21 Oct 2025 14:13 #262395
Yes a dial gauge is what I used. Could not remember the emglish Word for it earlier.
Thanks!
Thanks!
21 Oct 2025 21:08 #262399
by Busta
Replied by Busta on topic Quaife installation
I had a similar issue so I installed the Quaife diff myself and set the backlash by eye. The logic behind my method was that the required 0.1mm backlash is barely too small to see but big enough to feel, so that's how I set it. I didn't get it perfect so it's a little noisy now but otherwise it works perfectly and has lasted 20,000 miles so far with no issues. The oil comes out clean each time I change it so that's good enough for me.
It's annoying that there aren't more mechanics who are happy to take on these jobs. It's not complicated and dial indicators are cheap enough. I'd buy one if I had to do another.
Time to create page: 0.254 seconds
