Rear bearing eater
06 Oct 2025 14:05 #262191 by me101
Rear bearing eater was created by me101
Hi all. Any reason why a bearing would let go prematurely? I seem to get through rears regularly. Anyway, tried to go to Alps in June, but bearing went and no garage wanted to go near it. Put that one down to being sat for a while in silty water on Salisbury Plain. Only done about 3k miles, and 1 weekend in the Lakes with new bearing. Set off to Alps again, and same bearing has gone! Same story, limping back to Calais the scenic route. Any ideas on why? Ready for giving up on it. 2007, 78k on it.
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
06 Oct 2025 14:21 #262192 by fordem
Replied by fordem on topic Rear bearing eater
There are just so many possibilities here - incorrect parts, poor quality parts, poor workmanship and that is assuming the vehicle is stock & unmodified.
If you're running larger tires than stock, wider wheels, different offset, wheel spacers, and the list goes on.
By the way, I'm assuming you mean rear wheel bearings here, because you weren't specific.
06 Oct 2025 15:29 #262193 by Lambert
Replied by Lambert on topic Rear bearing eater
Could be many things but first off after it was changed because of having been dunked in Salisbury what else was changed and or inspected?
07 Oct 2025 07:02 #262202 by me101
Replied by me101 on topic Rear bearing eater
Hi, yes, rear wheel bearing. Fairly standard car, 215/75/15. Was done in a garage in France (eventually!). Doubt anything else was checked over. Parts unknown, just a bit gutted I have a second failed Alps attempt for same reason.
07 Oct 2025 08:24 #262207 by Lambert
My concern would be that all the contamination from Salisbury which I understand is much like abrasive paste may well not have been totally removed and caused this second failure?
07 Oct 2025 13:16 - 07 Oct 2025 13:16 #262209 by Motacilla
Replied by Motacilla on topic Rear bearing eater
Just to clarify, how did you determine the wheel bearing had failed on each occasion? What were the symptoms?
Last edit: 07 Oct 2025 13:16 by Motacilla.
Time to create page: 0.172 seconds
