ARB Air locker vs Quaife LSD with Jimny TC
- Thank you received: 1992
29 Sep 2025 12:31 #262128
Replied by Lambert on topic ARB Air locker vs Quaife LSD with Jimny TC
It should have driven straight out, certainly the 3 my neighbour had would have done..
29 Sep 2025 13:41 #262130
by 300bhpton
Replied by 300bhpton on topic ARB Air locker vs Quaife LSD with Jimny TC
29 Sep 2025 13:43 #262131
by 300bhpton
A dab of left foot braking would probably have helped, but difficult to tell without being there or seeing the exact situation.Personal experience - Mitsubishi Pajero with a torsen rear LSD, left two wheels on grass, right two wheels on asphalt ...
29 Sep 2025 16:54 #262132
by fordem
My point is the Quaife and any other torque biasing LSD requires some degree of traction on both sides for it to be effective, and that is not always present off road, or, as in the scenario I described, not guaranteed, even on road.
Choose your traction aid based on your planned usage.
Replied by fordem on topic ARB Air locker vs Quaife LSD with Jimny TC
That also works on an open diff - the next thing you're going to suggest is fiddle brakes.A dab of left foot braking would probably have helped, but difficult to tell without being there or seeing the exact situation.
29 Sep 2025 19:33 #262134
by 300bhpton
Left foot braking with an ATB is also a well established practice.
It can help with open diffs, but the results are massively different. Again, please watch the video of the Land Rover's I posted earlier. It is very clear to see how the diffs work and how they make 4 wheels spin instead of 2.
But driven correctly it would likely have provided enough traction aid to allow you to make progress or drive off. But as said, without seeing the exact scenario, it is very difficult to answer via a keyboard.My point is the Quaife and any other torque biasing LSD requires some degree of traction on both sides for it to be effective, and that is not always present off road, or, as in the scenario I described.
- The Coil Spring
- Senior Member
- Thank you received: 6
30 Sep 2025 15:21 - 30 Sep 2025 15:29 #262141
by The Coil Spring
But the other vid shows that Fordem is correct at his statemnt (at 10:19): We can see how only the RH rear wheel of the white truck spins despite it being equipped with a Thornton LSD.
Replied by The Coil Spring on topic ARB Air locker vs Quaife LSD with Jimny TC
Yes, I can see that at 2:32:Again, please watch the video of the Land Rover's I posted earlier. It is very clear to see how the diffs work and how they make 4 wheels spin instead of 2.
Last edit: 30 Sep 2025 15:29 by The Coil Spring.
Time to create page: 0.215 seconds
