Fuel pressure
22 Aug 2025 20:37 #261715 by MDA
Fuel pressure was created by MDA
I have a 1988  jimny with an F5 engine Model JA71V (Petrol)
Does anyone know what the fuel pressure should be regulated at?
I installed a new pump and inline fuel filter; it ran for about 1 week. Now when I try to start it, it sputters like it's not getting enough fuel and won't start. These are the same symptoms it had before I replaced the fuel pump and filter. I'm thinking the fuel pressure regulator is toast. thank you in advance....Michael
28 Aug 2025 10:35 #261758 by yakuza
Replied by yakuza on topic Fuel pressure
dunno about this engine as it haven't been available in Europe as i know of but the F10A wich is similar and same period has a side draft carb and should have 3.5 to 5 psi.
A faulty fuel pump is more or less the only bump you can run into with the f10a engines and the pumps can be easily sourced.
No available mech pump for the f5?
Time to create page: 0.138 seconds
