4 seater rear luggage mats
- aislinn__ok
14 Aug 2025 14:32 #261620
by aislinn__ok
4 seater rear luggage mats was created by aislinn__ok
Hi everyone, I just got my 4 seater 2025 Jimny SZ5. Luggage slides all over the place when rear seats are folded down, does anyone know where I can get a carpet/mat set or something for grip where the seats can still be folded up and down? Have seen one on Amazon but is unavailable. Thanks
- Thank you received: 667
14 Aug 2025 18:23 #261626
Replied by DrRobin on topic 4 seater rear luggage mats
I bought the genuine Suzuki rubber mat, it’s really good, but only fits in with the seats down. The rubber mat is this one
www.glynhopkinpartsonline.co.uk/products...bber-990e0-78r30-002
You can see the rubber mat here
www.bigjimny.com/forum/8-my-jimny/70258-...erland-jimny?start=6
You can also see the threaded Eye’s added to the sides, very handy for using straps.
I also bought some quilted mats which fit to the rear of the seats, something like these
www.aliexpress.com/p/tesla-landing/index...uXar_1xoCsYQQAvD_BwE
You can see these here
www.bigjimny.com/forum/8-my-jimny/70258-...rland-jimny?start=30
The work ok, but are still a little slippy .
I have in the past bought automotive carpet and used double sided tape, that would stop gear moving around.
Hope that helps.
Robin
Hope that helps.
Robin
15 Aug 2025 00:11 #261627
by facade
Replied by facade on topic 4 seater rear luggage mats
+1 for the rubber mat. They are available cheaper on that auction site.
It transforms the skating rink into a reasonably grippy surface, but the seatbelts bow it up a lot at the ends which is a bit annoying.
- aislinn__ok
15 Aug 2025 10:39 #261636
by aislinn__ok
Replied by aislinn__ok on topic 4 seater rear luggage mats
Super helpful, thank you!!
17 Aug 2025 09:07 - 17 Aug 2025 09:09 #261652
by facade
I looked at mine yesterday, and the part number moulded into the rubber is 99150-78R00-000.
The one they sell now, for the LCV, is 990E0-78R30-002
I'm not sure if the LCV and 4 seaters are exactly the same.
I keep my seats down 99% of the time, if I want to use them then I have to roll the mat up, and it takes up all the space behind the seats- or I can leave it at home........
Last edit: 17 Aug 2025 09:09 by facade.
17 Aug 2025 16:33 #261656
The LCV is different as it doesn’t have the seats or the tool box, so most likely this import will be the same as the 2020 SZ5.
To keep the seat belts from lifting the mat at the corners I pull them down flat and then put a bulldog clip round the belt on both sides of the top runner, this is enough too stop it retracting and lifting the belt and mat.
