Failing transfer box - front propshaft engaged.
31 Jul 2025 19:25 #261415
by IssacJay
Failing transfer box - front propshaft engaged. was created by IssacJay
Hi all,I’ve just bought an 05 Jimny VVT as a little project, but I’m completely new to working on them. I knew that 4WD drive wasn’t working but when I bought it, but I’m struggling to diagnose the issue. Symptoms:
- Green 4WD light just flashes continuously
- 4WD button does nothing – no click or noise from transfer box
- Front propshaft is engaged, which worries me a bit, but front diffs are not locked.
- Oil leak around the transfer box area but think it may be coming from the gearbox
- High-pitched whining sometimes when going into reverse, but persists in other gears (again could be gearbox or transfer related?)
- Thank you received: 1988
01 Aug 2025 03:30 #261416
Replied by Lambert on topic Failing transfer box - front propshaft engaged.
Welcome to the forum.
The persistent whine will probably be the main gearbox, from 05 to 09 these have an issue with the design of the internal bearings and are prone to failure.
The oil leak is probably through the centre of the output yoke of the front joint of the gearbox to transfer box drive shaft, they can either be fixed with epoxy or replaced with a newer one.
No 4x4 could be a few things but most likely it is that the vacuum pipes to activate the front hubs have corroded and are leaking, if the system doesn't see stable vacuum it will switch back to 4x2. Alternative being the wiring for the transfer box is damaged as it is fairly exposed under the car.
01 Aug 2025 07:57 #261421
by saxj
Replied by saxj on topic Failing transfer box - front propshaft engaged.
There is also a plug on the bottom front of the transfer case that is vulnerable to damage. Check that both wires are attached to the plug.
01 Aug 2025 08:09 #261423
by Busta
Replied by Busta on topic Failing transfer box - front propshaft engaged.
There's a good chance it's the actuator on the transfer case at fault. They sit unused for years (because most Jimny owners never use 4wd) and accumulate dirt and corrosion. Then a new owner get's in, excitedly presses the 4wd button and the actuator grinds into action and gets jammed up. In your case it's moved far enough to engage the front prop and that's it. Then the whole system becomes unresponsive and the light of confusion flashes.
They are DIY serviceable. Take it off and clean it up.
Then check your vacuum hoses and if they are problematic bypass the whole lot with some 4mm ID PVC hose. Another easy DIY job.
Time to create page: 0.195 seconds
