Front Wheel Hub Bolts?
25 Jul 2025 14:56 #261297 by wegotthemerch
Hello,
Looking to source a set of these bolts.
Want to confirm, are these are known as Vacuum Hub Stud Bolts, right?
For a Jimny 2018.
Any link to where I can get a set,
Much appreciated.
Thnx.
25 Jul 2025 16:36 #261300 by Lambert
Replied by Lambert on topic Front Wheel Hub Bolts?
Drop Martin in the shop in the top banner a message and he'll get you sorted.
25 Jul 2025 17:27 #261301 by wegotthemerch
Much appreciated Lambert!
Thank you for the assist.
27 Jul 2025 07:42 #261319 by Busta
Replied by Busta on topic Front Wheel Hub Bolts?
Do you specifically want the OEM bolts with the awkward E10 head or just a bolt that works for the application? They are standard M8 bolts. I can't remember the exact length, it's about 40mm but I can measure if you need to know. I replaced mine with cap heads that take a 6mm hex, because that's a tool I own several of and much more convenient.
Time to create page: 0.322 seconds
