Irritating noises.
25 Jun 2025 12:49 #261021 by facade
Replied by facade on topic Irritating noises.
Good so it's just like the 3s and doesn't seem to upset the rest of the car. Excellent.
I followed that link today as mine was being particularly irritating this morning, and it occurs to me that it is the "key in the ignition" switch you are disconnecting.
Often, as well as triggering the beeper, that switch is used to disable the remote locking if the key is in the ignition. You never notice until that switch breaks and you wonder why the car won't lock! (because you have to be holding the key to press the button, so it is never in the ignition)
You might be able to lock yourself out of the car if you try really hard while the engine is running- maybe closing the door with the handle up could trigger it
25 Jun 2025 14:06 #261024 by Lambert
Replied by Lambert on topic Irritating noises.
Just tried that and it seems that lifting the handle is the only way to do that. Fortunately it's not something I am in the habit of doing. I'm more likely to leave a door open than ever lifting the handle. I seem to remember that subaru was good at locking the keys in and that taught me that lesson. Cheers for the heads up.
25 Jun 2025 17:37 #261027 by jlines
Replied by jlines on topic Irritating noises.
I'm not sure you can disable it. If you're in & out of gates can you not just leave the car running so it doesn't beep? If your out the car for a while then just turn it off with the keys out of the ignition? I usually leave my jimny unlocked all day at work with the keys in my pocket and it rarely locks itself. Sometimes I also leave the keys inside and it hasn't locked me out yet!!!
26 Jun 2025 03:23 #261034 by Lambert
I'll keep observing what it does in different scenarios but on the face of it it's behaviour is the same as temeraire and dreadnought who had the beep disabled for over a decade between them.
28 Jun 2025 13:48 #261068 by facade
I remembered to test the remote locking today, and with the key in the ignition (and all the doors shut to stop the noise) the lock/unlock buttons on the key don't do anything, as I expected.
I can't imagine any scenario where you would accidentally press the lock button on the key with it in the ignition and lock yourself out though.
I suppose you could lock it with the spare remote key, and leave it locked with the ignition key in and visible, inviting theft, but that seems pretty unlikely.
Time to create page: 0.281 seconds
