Locking Hubs
- chayes0106
10 Apr 2025 14:21 - 10 Apr 2025 15:11 #260093
by chayes0106
Locking Hubs was created by chayes0106
Hi all,
I'm sure this has come up lots of times before. I recently got a 2005 jimny which has the front locking hubs, but the 4x4 will not kick in and when 4L is pressed it beeps. I have tried looking at what was done and followed the steps with blocking the valves which wasn't done. I'm also not getting any warning lights or flashing green light. When i press the button i can hear a clicking sound as though it is trying to complete the process.
Would anyone have a idea what else to check?
Last edit: 10 Apr 2025 15:11 by chayes0106.
- chayes0106
10 Apr 2025 14:29 #260094
by chayes0106
Replied by chayes0106 on topic Locking Hubs
Also is there anyway I can manually lock it in 4x4 eliminating the button?
- Thank you received: 2001
10 Apr 2025 18:22 - 10 Apr 2025 18:24 #260097
Replied by Lambert on topic Locking Hubs
Simplest thing first, you are stopped and pressing the clutch when selecting 4lo?
Last edit: 10 Apr 2025 18:24 by Lambert.
- chayes0106
01 Dec 2025 10:28 #262956
by chayes0106
Sorry for poor reply, yeah ive been stopped with clutch down.
- Thank you received: 673
01 Dec 2025 17:16 #262967
Replied by DrRobin on topic Locking Hubs
Since you have manual locking hubs, the clicking sound is either coming from the transfer case (under the centre of the car) or possibly from the solenoids on the vacuum system for the vac hubs (near the battery).
You don’t need the solenoids to be working if you have manual hubs, but then you should get a flashing green light to say the hubs aren’t locked and you are not.
Either the 4WD controller is not working correctly or the transfer case is not switching in to 4WD, possibly the TC actuator or may be the switch in the TC to say it is in 4WD.
The wiki has a very good section on diagnosing faults, I added a link to your other topic.
Robin
Robin
Time to create page: 0.176 seconds
