Shock extenders on already 2 inch lift
31 Mar 2025 09:32 #259987
by nutter2
Shock extenders on already 2 inch lift was created by nutter2
Hi all,
I have a gen 3 which had black raptor shocks, when i bought the kit the seller recommended i fit the brackets shown below to the bottom of the rear dampers... to take pressure off the bottom of the mounting points. Apparently it puts them at the correct angle ?
anyone heard about this before? Is it advisable to use them ? I dont have thrm fitted atm just wondering if i should?
Thanks
Thanks
31 Mar 2025 10:48 #259988
by fordem
Replied by fordem on topic Shock extenders on already 2 inch lift
There's another discussion on this and the general consensus seems to be don't fit them.
www.bigjimny.com/forum/7-jimny-technical...tion-brackets#259489
The following user(s) said Thank You: nutter2
31 Mar 2025 12:21 #259990
by Busta
Replied by Busta on topic Shock extenders on already 2 inch lift
The rubber bush in the shock is already there to allow for changes in the shock angle, and does a fine job. These brackets generally cause more issues with bent or broken shock mounts as they cause the suspension to bottom out on the shocks rather than the bump stops. They might also cause your springs to dislocate (fall out) on full extension which is not desirable. I'd recommend against fitting them.
31 Mar 2025 17:09 #259993
Replied by yakuza on topic Shock extenders on already 2 inch lift
When doing a flex test by driving one wheel onto something tall, it is possible to see and feel if the dampers are binding or the springs come loose from their seat. When doing this test on my car with a 2" trailmaster lift I could clearly see that the rear springs came off their seat, and by wiggling the shocks I got the impression they where not binding. I added a 25mm rubber spacer to my rear springs and now it suits the lift and load of the car better.
And the most important thing, there is now more headroom under the awning.
the Trailmaster shocks are just a bit longer than the black diamond ones so they have room for a small spring spacer.
31 Mar 2025 17:28 #259994
by nutter2
Replied by nutter2 on topic Shock extenders on already 2 inch lift
Thanks guys I guess not to fit them after reading that thread.
Time to create page: 0.325 seconds
