Headlights adjusting tool
14 Mar 2025 20:11 #259800 by lightning
  lt looks like you need a special tool to adjust the headlight alignment on the Gen 4 Jimny. The MOT tester adjusted them as he insisted they were set too high. I told him they adjusted themselves as soon as you drive away but he did them anyway.
I actually saw the headlights adjust down as he reversed it off the MOT ramp.
Anyhow, now the cutoff is about 15 feet in front of the vehicle and the dip beam is useless on an unlit road.
I have looked on Ebay but can't find the correct tool. ls it available anywhere?
14 Mar 2025 20:53 #259801 by fordem
Replied by fordem on topic Headlights adjusting tool
The headlights can be adjusted using a large flat blade screwdriver.
14 Mar 2025 21:04 #259802 by mlines
Replied by mlines on topic Headlights adjusting tool
Small socket on the head , 8mm?
You can see me use a socket in this video on the dip unit which achieved the same thing
14 Mar 2025 22:33 #259803 by DrRobin
Replied by DrRobin on topic Headlights adjusting tool
I did mine in both vertical and horizontal using a socket, no problems at all.
I used a wall to adjust them which worked fine (vertical is perfect and both dip beams Z beam overlap at the correct distance, but in the fog last weekend they are slightly out to the left so will make another adjustment.
Before I started I got flashed at all of the time, now no one flashes at me and they are still good enough for the speed of the vehicle.
Robin
The following user(s) said Thank You: lightning
14 Mar 2025 23:32 #259804 by lightning
Replied by lightning on topic Headlights adjusting tool
Can you tell me which is the vertical adjustment and which is the horizontal?
15 Mar 2025 07:32 #259805 by mlines
If you do it on the dipping motor you get vertical only
