Gen 3 2007 Jimny struggles when at around 75-80mph
02 Mar 2025 23:44 #259667 by DrRobin
I am not surprised it’s struggling at that speed, you are not far away from maximum speed. My Gen3 felt best around 50-55mph, my Gen4 slightly higher at 55-60mph, above that wind resistance starts going up.
I doubt I have ever been over 70 in a Jimny.
03 Mar 2025 05:37 #259668 by Lambert
The only two times I have had meaningful issues with windage were once in a cross wind on the A1 near Coldstream that was unpleasant and then again I decided in October last year that being on top of mountains on the west coast in 90mph storm conditions was probably not worth the risk but otherwise it just uses more fuel to maintain progress.
03 Mar 2025 08:58 #259671 by Motacilla
You are thinking crank sensor
But at this speed it could be other things
Coil pack, fuel starvation, partial blocked cat/rear silencer
Not many people push em past 70mph
I agree with this.  It is not so much the speed per se, as the fact that to push a Jimny that fast you are not only running at higher rpm but also at a higher loading (to counteract aero) and for a longer time.  In other words, you are really putting a lot of power (aka heat aka fuel) through the motor to maintain that speed.
I could definitely see a coil pack overheating, maybe plugs or wires too.  And your intake and exhaust paths should be pristine, to handle that kind of sustained flow.
Of course nobody wants to hear it, but the Jimny is wildly unsafe at those speeds.  High unsprung weight, high CG with narrow & short wheelbase, and lousy brakes.  There are better ways to prove how tough you are.  But if you want to persist in using the wrong tool for the job, there is some diagnostic work to be done.
03 Mar 2025 12:57 #259678 by Lambert
As someone who has used a jimny as a track day toy all be it with a few gucci upgrades I wouldn't go so far as to say it is the wrong tool for the job, it works surprisingly well if you are reasonably competent.
25 Mar 2025 07:13 #259899 by Me and my Jimny
Last time my missus did 70 the transfer case went bang. Shes now banned from driving it except off road
When my crank sensor went it was struggling to idle when it got hot so i suspect something else if you get to that speed. But I'm no expert
25 Mar 2025 14:54 #259908 by Rogerzilla
Gen3 manual was ok at 70mph if it wasn't too windy.  Gen3 auto is better at 70 bevause of its longer gearing,but it takes an age to get there.  Gen4 manual is pretty nasty at 70.  It has more power than the gen3 but it's raucous.
I generally keep it to 60 because the car is more comfortable at that speed and fuel consumption is less tragic.
Time to create page: 1.029 seconds
