Gen3. Man ual Hubs fitted.
27 Jan 2025 12:40 #259248 by Mert1
Hi,
I have recently fitted manual hubs on my 2016 Gen 3. I fitted them on my previous Gen 3. as well. I have been reading all the threads on how to short out the switch so that I do not  have the 4 x 4 flashing lights when I engage 4 wheel drive.  ( I can't remember what I did on my previous Jimny.) Unfortunately I can't find anything that tells me really clearly which switch I disable and where it is. I understand how to block off the vacuum pipes, it is only the switch I am unsure of. Some of the threads I have read I'm not sure if they apply to a 2016 Jimny or not. I would be very grateful anyone could help me out.
Thanks in advance,
Martin Verdeyen.
27 Jan 2025 20:12 #259251 by Busta
Replied by Busta on topic Gen3. Man ual Hubs fitted.
Under the battery, next to the vacuum solenoids is a white 2 wire connector for the vacuum switch. That's the one that needs bridging to trick the system into thinking it is holding a vacuum.
The following user(s) said Thank You: Filipao
28 Jan 2025 13:37 #259260 by Mert1
Replied by Mert1 on topic Gen3. Man ual Hubs fitted.
Thanks Busta,
As soon as I get time I'll go out and take a look.
Martin.
28 Jan 2025 13:45 #259262 by DrRobin
Replied by DrRobin on topic Gen3. Man ual Hubs fitted.
When I changed to manual hubs, the pressure system and solenoid valves were still working, it was the complicated metal and flexible vacuum tube down to the wheels which had gone, so rather than taking the wires off the pressure switch, I just pulled the flexible hose off the 'lock' solenoid + pressure switch and plugged the end of the tube.  Then when I engage 4WD, the lock solenoid still activates and a vacuum is seen by the switch.  When the 4WD is de-activated the vacuum switch returns to normal.
I did it this way so it could be easily reversed, which I did do prior to selling the vehicle, I installed new vacuum lines to the hubs and removed the plug.  Plus plugging the hose was easier than trying to reach the electrical terminals, but only works if some of the vacuum system is still working.
Robin
Time to create page: 0.499 seconds
