Drop roof liner Gen 4
08 Dec 2024 19:10 #258658 by Steve G
Hi all, need to drop roof liner on gen 4 to fit a new aerial. will the air bags go off when i undo the the front seat belts at the top as the trim behind them needs to be removed. Thanks.
08 Dec 2024 19:17 #258659 by Motacilla
Replied by Motacilla on topic Drop roof liner Gen 4
No, the airbags won't detonate if disturbed, like a hair-trigger landmine. That isn't how airbags work.
You'll be fine, carry on.  Post some pics of the bare roof if you get a chance, I'm sure they will be useful to someone here in the future.
09 Dec 2024 06:52 - 09 Dec 2024 06:53 #258662 by Motacilla
I should add: the risk is actually the other way, that you will damage the airbag not the airbag damaging you.
I assume you are proceeding carefully and (for example) not using sharp tools around delicate interior components. But for others who are not so careful, it is important to keep in mind that the airbag fabric is very easily cut or perforated. Sticking a boxknife or screwdriver into your airbag while running speaker wire is one way that the more ham-fisted among us create airbag safety problems: an airbag won't work well in an accident when your hi-fi installer has punctured it.
But again, airbags don't explode when disturbed; that is a widely-held but nevertheless quite mistaken belief.
Last edit: 09 Dec 2024 06:53 by Motacilla.
09 Dec 2024 07:34 #258663 by Lambert
Replied by Lambert on topic Drop roof liner Gen 4
I'm assuming that you are having to run an entirely new loom and everything as I would have thought that for just the ariel it would be possible to access the roof structure enough just at the back and supporting the liner down partially with a suitable block or rod?
Time to create page: 0.168 seconds
