Install Power Steering
07 Nov 2024 15:38 #258220 by fordem
Replied by fordem on topic Install Power Steering
It seems we have a different approach to shopping for parts, and we're not looking at the same parts catalog - take a look at this link...
www.megazip.net/zapchasti-dlya-avtomobil...teering-link-3821057
You'll see this line near the top...
Steering link (SN413V:LHD:N/PS) Diagram Suzuki JIMNY
Notice the N/PS - it means no power steering - it means the SN413V, was sold without power steering.
I'm using megazip.net as an example simply because it's easier than a cut & paste from the catalogs I normally use, that page is for Pacific market models (Australia & New Zealand), but the European markets show the same thing - Jimnys were built for sale without power steering.
08 Nov 2024 15:35 #258228 by Rogerzilla
Replied by Rogerzilla on topic Install Power Steering
Does the power steering talk to the ECU or the ABS control unit (if fitted) in any way?  Steering angle is often an input for other vehicle functions.  Maybe the Jimny isn't quite that advanced.
08 Nov 2024 15:40 #258229 by fordem
On a 2004, it would have been hydraulic power steering, there would have been a pressure switch on the pump that sends a signal to the ECU to "bump" the idle if the steering is turned with the vehicle stationary, all the ECUs should have that input, other than that, if it has traction control there might be a steering angle sensor.
09 Nov 2024 01:46 #258234 by JennyR
Replied by JennyR on topic Install Power Steering
It definitely hasn't. Daughter had it for 9 years before me.
09 Nov 2024 01:50 #258235 by JennyR
Am in Oz and does exist here
09 Nov 2024 05:54 #258238 by Lambert
Replied by Lambert on topic Install Power Steering
Ah Australia explains it. Yes you can do it and as suggested finding a donor in a dismantlers yard is going to be the easiest way to get all the parts for sensible money.
Time to create page: 0.169 seconds
